4,784
Also, Here is the design I was thinking of going with. Is there anything that wouldn't fit inside the case?
http://pcpartpicker.com/list/2HjvRG
If you're planning on getting a Cerberus-X and assuming there's enough demand to produce it, then you should be fine. But the default case is microATX while the board you have selected is ATX.
Also, when can I expect the case If I order by Christmas?
It's too early for us to be making time estimates.
deleted
www.reddit.com
Thanks! Also, a Windows 10 Drive Ebay is a "backup/repair/reinstall" flash drive, which basically allows you to get a full version of windows 10 for $16, instead of the original $80.
K888D
Lazer3D
Feb 23, 2016
1,483
2,970
www.lazer3d.com
Does it includes the license? That's the bit you pay $80 for! The installation files are available for free from Microsoft and you can load them onto any 4Gb+ USB drive.
Shattucknick
Pretty nice case I like it. Awesome modular concept. Would like to see perhaps a vertical mounted GPU or an mITX version one day (not that this couldn't fit an mITX.
4,784
Also, I've been seeing quite a few pics of the nova case, which looks exactly like Cerberus. are these the same thing, or is nova a knockoff?
Nova is the original version, we changed the name to avoid confusion with the BitFenix and CaseLabs cases that are named Nova.
We probably won't do either of those, the CaseLabs Bullet BH4 is a good compact, horizontal motherboard mATX case and the NCASE M1 is a great ITX case with this layout.
deleted
www.reddit.com
I know that someone has probably already asked this already, but can this case fit a Corsair 240mm aio cooler, like the h-100 with a sfx psu? Also, can a 2-way sli gtx 1070s fit 2 140mm fans beneath them?
4,784
Assuming the video cards are air-cooled, then the only way that will work is to have the PSU rear-mounted and put the H100 on the front (assuming the cards are not so long that they'd interfere).
Then if the video cards are not spaced then 25mm thick fans can fit on the bottom, with spaced cards then only slim fans will fit on the bottom.
PNP
285
257
For air cooled cards, I think it may be more efficient/quieter to just use (a) fan duct(s) and use the card's own fans to draw air from the bottom.
