As you mentionned, fan control by bios could be limited.I like it so far. (Thanks for advice!!!) I am going to try and help airflow without swapping the Prism first (it'll probably be a futile effort. My spouse's rig is running a sweet setup with a Noctua CPU fan (and it's quite quiet)).
Here is how it sets right now.
Here are my thoughts on fans:
1.) Considering a 92mmx15 on the back as an intake, but that might not move enough air. Do you think I should skip straight to the 92x25?
2.) definitely go w/ top 120 slim as exhaust
3.) What about adding another 120mm as an exhaust for the front? That way the heat of the gfx card has somewhere to go, especially with an inverted SF600. I'd have an intake on the bottom and an exhaust on the front.
Cables:
1.) Ok i'll skip the right-angle connector. As far as the existing angled cable. Is there a "left-angle" or essentially a 90 degree that is opposite to the direction of the existing one? I'm putting a severe bend into the cable with the SF600.
2.) Have you seen anyone order a specific length of custom cables for this build? Would be beneficial for removing clutter and getting a better air path.
Asus is imposing cpu temperature limit of 70°C by default, that can extended to 75°C...leading to fan spinning at 100% when CPU is reaching 75°C.
Please make sure you adjust properlly your fan curve in Q-Fan.
In terms of cooling :
- As rear intake fan, Slim nf-a9x14 is ok to be honest.
- Definitely a must have..
- I guess it won't be useful. By experience, your bottom fan is pushing all hot air in CPU area. I assume front exhaust fan will even decrease performance of bottom fan.
