Boil
1,253
1,094
Quick question to all here... Is there top fan mount (dual fan) limited to 120x15 or has anyone fit in a 120x25mm?
I want to say the 15mm limitation is only if you are using an ATX PSU over the motherboard...?
EDIT - Nope, I am wrong...!
Nyven
21
Using the vented top panel piece I have a EVGA 1080 TI Hybrid 120x25mm fan/rad mounted on top exhausting. Only worked with the vented top panel becuase I could move it off center closer to side panel away from motherboard. The rad/fan barely fit between the power plug entering in the back and the ram on the motherboard(asrock z370 taichi). And height wise it is almost touching the cpu water pump and mounting screws. Like a millimeter or two clearance on all sides.... so pretty much a perfect fit for me.
Reactions: Bioforce
harryoui
@KSliger is there a sketchup or 3D model file available for the Cerberus X? I've seen screenshots from one but being able to place the parts would make build planning a lot easier
KSliger
Sliger Designs
May 8, 2015
855
3,186
It's Kimeras design so I cannot release anything. Anything in particularly you need help ensuring fit for?
MarcParis
Apr 1, 2016
3,835
2,997
Good news for litterally power user in cerberus case : Seasonic is realising a 800W titanium SFX L..:)
Pretty good alternative to SX800 LTI..:)
harryoui
I'm essentially trying to overcome the PSU interference and fit a 240mm radiator to the side hinge area.
Hope my kiddie drawings make sense, @KSliger
First idea is to reverse mount an SFX PSU using a corsair adapter
Second idea is to mount the rad externally
Boil
1,253
1,094
LOL. I am watching this at the time of my posting...!
Corsair 750W Platinum SFX versus Seasonic 800W Titanium SFX-L versus Silverstone 1kW Platinum SFX-L...?
The Seasonic Connect is, interesting...?
MarcParis
Apr 1, 2016
3,835
2,997
Seasonic connect is too much focused on specific case to be useful to be honest...cable ties are doing the same in an inexpensive way.
But you are battle on SFX-L is more than welcome...SX1000-LTP is enormous...i wonder how is exactly connection system...especially on a double 8 pins cpu plug.
KSliger
Sliger Designs
May 8, 2015
855
3,186
I really do not see it fitting, the length of the 240mm radiator and the thickness of the SFX PSU just make it impossible.
You could try and custom mount the PUS rotated 90 degrees, but that would require a ITX motherboard.
Also people that noted shipping costs were too high over the weekend please try again, changed a setting and shouldn't have, have it fixed now!
Reactions: harryoui
Bioforce
251
116
Of the currently announced ATX/EATX X570 motherboards, do any happen to look like they might allow for 25mm thick fans to be used in the top of the case?
Bioforce
251
116
None of them seems to allow it. Even the cheapest ones have beefy VRM heatsinks at top.
I figured as much. If anyone happens to find one that does allow 25mm fans somehow, be sure to let everyone know. It would be great to have an X570 board that doesn't limit exhaust options.
MuffinCrumbs
46
34
So after making a big mistake on last Black Friday, getting a gigantic ATX PSU, the HX1200i, I changed it to SF750.
It helped, when it came to cable management. Not sure if it can get any better. It probably can. Tinier cables really helped.
The only problem with changing to SF750, was that it didn't have enough PCIe connectors. I had to plug in 2x for CPU (8+4 pin to the motherboard), 2x for PCIe (for graphics card) and 1x for PEG on the motherboard. Since SF750 only has four CPU/PCIe connectors, I had to ditch the one for PEG.
Now, this computer didn't really need a power connection for PEG, as it doesn't have more than one graphics card. But still, it is a loss, in my opinion.
Anyway, this is the result..
rcradiator
117
79
That's a Z390 system with a 9900K, right? Don't worry about the 8 pin EPS. Almost all cpus on mainstream platforms (except maybe the 3950X overclocked) can run with a single 8 pin EPS unless you are going nuts overclocking the cpu. An 8 pin EPS can deliver over 200w of power (watch Buildzoid talk about it here). You only really start needing that extra 8 pin EPS once you start getting into HEDT platforms like the X299 and X399 platform where the cpu can pull in excess of 300W no problem. The SF750 was actually designed with HEDT systems like the Corsair One Pro i180 in mind, which uses the power hungry 14 core 9920X cpu. For mainstream platforms, a single 8 pin is fine as you will never hit the power draw figures of HEDT. I guess you can plug in for peace of mind though if you are worried about a single 8 pin passing through 200-250w as I believe most dual 8 pin setups are wired in parallel, so plugging in two cables means each cable shares half the load.
Reactions: MuffinCrumbs
MuffinCrumbs
46
34
Thank you so much. This is very informative.
You're absolutely correct. The motherboard is a Z390 chipset, with i9900K. I'm not planning to overclock it, so I'm very pleased to know this information you've just told me.
I thought plugging both EPS would be better, than neglecting PEG completely. But it seems like I don't really need two power connectors for the EPS.
MarcParis
Apr 1, 2016
3,835
2,997
I confirm that even on X399 threadripper MB, you don't need second EPS 8pins if you are not planning to OC beefy CPU too.
I still don't know if I will update my system this year, either with Ryzen 3000 series cpu with/without changing MB.
This Aorus X570 extreme (with fanless X570) is an expensive monster...
https://www.aorus.com/X570-AORUS-XTREME-rev-10
Ryzen 9 3950X + Aorus X570 Extreme is awesome but worth 1350$...:D
MuffinCrumbs
46
34
I've never heard of a motherboard costing that much. Sounds like a dealbreaker, even for those who'd have the money for it. Not sure if it is, however.
MarcParis
Apr 1, 2016
3,835
2,997
Apparenlty top end of Motherboard are reaching 600$ nowadays...
Strangely enough I guess best MB to jump on Zen 2 will remain B450/X470 motherboards...to be checked in 3 weeks, with first reviews..:D
