I used a 15cm cable for the 24pin, but it's a very tight fit. 20vm would be still tight, but more manageableI figured I’d get a ball figure before moving forward with measurements.
SX800-LTI@carpenike marvellous build so far! What sfx-l psu have you chosen?
SX800-LTI
Imgur post, last pic
@carpenike I think I might have been the one who sold you the Hydrocopper on /r/hardwareswap lol. I hope it came out of shipping alright![]()
i have aquaero 5lt in my case. Ill show you my setup in a few hours.Solved my other temp control question, ordered a Aquacomputer Aquaero 6 LT that I'll hide in the bottom front of the case or behind the cross bar.
Good choice!!! Love your build!Solved my other temp control question, ordered a Aquacomputer Aquaero 6 LT that I'll hide in the bottom front of the case or behind the cross bar.
Optimum Tech with another Cerberus build. A Threadripper 2950X this time:
YEAAAAAAAAAAAAAAAAAAAAHHOptimum Tech with another Cerberus build. Threadripper 2950X
Ahah i could have tell you that..Heh, so the SFX PSU arrived, but it doesn't have an ATX adapter, so now I need the SFX rear mount for the Cerberus. Another couple day delay.![]()
Completed my loop, will water test while waiting for rest of parts. Didn't intend to not use tubing, but all the spaces were so small that it was easier to just use the fittings...
