galletabah
136
88
spain
After why do you want to watercool a FTW3 as it's a great performer already in air? Performance advantage linked to watercooling is very minimal on Pascal (and even on Turing).
I think, the best combo on this case can be c14s with gpu watercooled (no more hot air into it) with rad in both or front.
ftw3 is 4 degrees hotter than asus strix, but was dual slot and I put it in a dan a4 sfx while cerberus come to home.
What do you think about that?
Ps: I can get a 1080ti aorus, 149mm (I think we have 152mm o cerberus?)
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
If you are not a huge cpu overclocker, going to Noctua C14S (fan in exhaust mode) + dual 120mm intake fan at bottom + FTW 1080ti is a great combo, full & effective air cooling.
I've done this combo with my Cerberus-X and MSI Gaming X GTX 1080ti...it was my best setup giving best gpu temperature and noise.
https://smallformfactor.net/forum/t...-x-complete-build-log.2007/page-13#post-62556
Reactions: loader963
galletabah
136
88
spain
But i think with a waterblock in gpu you can get internal's "cold" air. You have not a 75° component in the case, you replace this aire with a radiator with 40-45°
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
@MarcParis
When are you taking the plunge to full water cooling, you’ve done exhausted every other air cooling setup !!! :D
Well, answer is simple : never on this setup as my Gaming X GTX 1080ti is too tall to receive waterblock inside Cerberus.
To be honest, I'm less and less insterested to watercool GPU as lower temperature is not bringing significant gain, at least on Nvidia Pascal (or Turing). If I was on Vega 64...watercooling is still effective as it's a toaster and auto frequency booster is less restrictive than Nvidia..;)
fabio
1,885
4,325
Wait wait wait! Than, because I am trying to go with the 2 TItan V watercooled, and in future at the bottom a blower style GPU, you suggest the bottom radiator to be configured as intake or exhaust? The build is getting closer and closer! Finally DHL has found my CPU :cool:
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
as far as i remembered I'm betting on full exhaust on your setup..:)
galletabah
136
88
spain
Hi guys!!!
Ekwb phoenix is compatible with cerberus matx? I think so but confirm that can be awesome
I'll buy all for my build log and I want be ready
Thanks !
VegetableStu
1,949
2,619
okay it's kinda tricky: https://www.ekwb.com/shop/EK-IM/EK-IM-3831109863800.pdf (see marked page 9 for orientation limitations)
the case would only fit the 240mm Radiator model according to my notes
  • it can't be mounted at the bottom due to the pump not getting enough water flow, unless you don't mind laying your case on its side forever
  • it can mount at the front. you might not be able mount the top or bottom 2 out of the 8 screws of the fan (depending of the offset), but otherwise that'll be the one with least functional issues. You'll need a rear PSU mount plate for this
  • Side hinge is doable, but there won't be space for any standard PSU mounting
    (unless you're okay with mount the PSU by its fan elsewhere. if you're doing this, you'd need the front PSU bracket for the power extender cable)
GPUs, as mentioned, only reference heights (no MSI Gaming X or ASUS Strix)
galletabah
136
88
spain
Yes, this will be a big problem. I want less pipes and WC components in the case to get more space for other stuff.
So, another time to the drawing paper...
galletabah
136
88
spain
well i just see in the sliger page:
  • Maximum card height: 152mm (bottom of card PCIe tab to top of power connector wires)
But i dont know if i can fit 1080ti aourus(149,27mm) without problems
