@Taswegian thanks for the reply. As to your question re: mITX board - I already have a board that sits nicely inside of a Ncase M1 using one 120mm H55 for CPU (i7 7700 non-K) cooling and another H55 for GPU (modded R9 Nano) with two 120mm Noctua fans on the bottom of the case cooling both the GPU and sending some airflow towards the top. I think I'm getting great temps (idle 29-30 on both, and 45-50 on CPU and 50-55 on GPU while gaming), but I feel with the AIO tubbing everything is crammed in very tight. Not to mention I'm planning on selling the MSI Z270 Gaming Pro Carbon AC + i7 7700 next month and getting the 6-core 8800 or RYZEN 2 and I'm worried that H55 might not be enough to cool a future 6 or 8 core CPU (even the non-K or 65W RYZEN 2 ... and I like things quiet)
At first I was eyeing the Define Nano S to go to, but I've gotten used to the material quality of the M1 so when I checked out the Nano S again, it felt cheap (no offense to Nano S owners) and that's when I remembered the Cerberus - my ultimate goal was to cool the 6-8 core CPU with a 240mm AIO rad, and do the same for the GPU (be it current R9 Nano, future Nano, or something like the Zotac 1080 Mini). I'm not planning on doing a custom loop - I'm happy with AIOs even though that might not be a pretty or a very efficient solution - I just wanted a bit more space.
@Sancus thanks for the reply.
@MarcParis thanks for the reply, I don't mind tweaking the case a bit, or even a lot ... I was even thinking (if I had the time) of doing a complete mod where I'd "move" the mobo down a bit and create room in the top area for another 240mm AIO. So the Cerberus would have unvented sides, one 240mm AIO on the bottom for GPU, one 240mm up top for CPU, and my current SF450 or SF600 in the front of the case.
I might be overthinking all of it, and worry about temps/noise too much - but that's another story
