vPost: $15.24 from Sliger to OR + $43.80 (USD) via vPost Economy
Total: $59.24 minus tax
Going by sea might be the bit cheaper ($46.58 total), but it says in site it has to be more than 10kg ._.
After threadripper + 4 Titan V, here is Cerberus-x with dual CPU!!Figured I'd share as well... My use-case is a little different from the other users from what I see.
My Cerberus X is an unraid server/nas and htpc/dvr for 3 TV's in the home. The 140mm Prolimatech fans turned out to be the best noise/performance fans I can fit into the case after trying various Noctua models.
they'll be updating the site soon, along with more cases if I remember rightwebsite specs.
Figured I'd share as well... My use-case is a little different from the other users from what I see...
Awesome setup!
I've been waiting for a build like this to pop up Very well done!
Windowed panel?..Thank you! I was super excited to find out about this case and had to pull the trigger to "complete" the setup. Even if the hardware changes in the future, this case will surely stick around.
Now to find some stickers/decals to spice it up...
what did you end up using instead of the H7?How is the H7 working for you? I found it wasn't enough to keep my 1700 cool enough for my OCD to not kick in (occasional spikes in temp to 41-45 C from 32-33 C drove me nuts because of my fan curve as well as my obsession to keep the CPU as cool as possible without watercooling), but that's just me being absolutely paranoid and nuts.
Ended up using a Scythe FUMA rev.b which just barely fits (top of fans kinda touch normal side panel, heatsink doesn't though), temps are absolutely amazing though as I haven't seen over 60 c with prime95 29.3 small fft (supposedly the hardest you could hit your CPU). I did end up modding a side panel for tempered glass which gave an extra 1.5mm clearance and solved the issue with the side panel touching the fans. Do be aware that it might not fit for you as every millimeter matters height wise.what did you end up using instead of the H7?
What?! My beloved Scythe Fuma is fitting inside cerberus?!Ended up using a Scythe FUMA rev.b which just barely fits (top of fans kinda touch normal side panel, heatsink doesn't though), temps are absolutely amazing though as I haven't seen over 60 c with prime95 29.3 small fft (supposedly the hardest you could hit your CPU). I did end up modding a side panel for tempered glass which gave an extra 1.5mm clearance and solved the issue with the side panel touching the fans. Do be aware that it might not fit for you as every millimeter matters height wise.
What cpu are you using?
Excellent, I ordered a Scythe Fuma Rev. B recently, although I'm not planning to use it in the Cerberus, it's good to know it fits !Ended up using a Scythe FUMA rev.b which just barely fits (top of fans kinda touch normal side panel, heatsink doesn't though), temps are absolutely amazing though as I haven't seen over 60 c with prime95 29.3 small fft (supposedly the hardest you could hit your CPU).
Maybe you can give it a try.. Just for science and knowledge..Excellent, I ordered a Scythe Fuma Rev. B recently, although I'm not planning to use it in the Cerberus, it's good to know it fits !
Hi there, is it possible to install a 240 AIO? or two 120mm AIOs on the bottom if I were to use a mITX board?
