So I took a chance and ordered the Ncase bottom filter. If it fits I will mention it here so noone else has to take a chance. I know I could have just measured and had them custom make one but I ordered from Amazon so it would get here faster.
https://www.ebay.fr/itm/2x-120mm-Co...-Fan-Case-Cover-Dust-Filter-Mesh/182281834885Any suggestions for fan filters?
No. Outside of using double-sided tape the brackets are needed.
Woof. You'd think at least one 3.5 bracket/cage would be thrown in, seeing as it is a premium ATX size case, whereas smaller premium ITX cases have brackets by default. Oh well, what's another 50 dollars at this point.
Maybe he wants to put 6x 3.5" drives in his case?
Your brain is surprising..my brain suddenly went “custom bottom face with hot-swap SAS bays”
portable unraid server o_o
Maybe and not to be rude but if that's the case I think there needs to be a bit more thought put into how that's going to impact airflow.
I didn't use them for anything, but what are the big self-tapping screws supposed to be for, anyway?
Hi guys. Between the white and red cable
Lol I'm curious too, I had no idea what to do with these.
Those are fan screws. I used them for my 120mm Fan on the side bracket.
@TheHig is right, fan screws.
It's entirely possible, though when I was rearranging things in my build today I removed the drive from the bracket entirely and didn't notice anything that seemed unexpected, or shrapnel.might you have tapped the HDD screw threads...? o_o
