Do you have information detailing the difference between the new velka 5 and the vleka 7? I saw the spec and pics, but more information would be awesome. (More pics showing the layout or the back of the case would be nice)
At the moment, I can only suggest checking back next week because I don't have enough information to decide how to go about orders.
As for the rumored RTX 3080 design, I think it looks very unconventional and unnecessarily difficult to manufacture. This is supposedly one of several suggested designs and if Nvidia decides to go in this radically new direction with the cooler design, the high end (RTX 3080 and up) reference models will cause compatibility issues with most SFF cases. However, this leak doesn't say anything about the board partner's designs nor the reference designs for RTX 3070 cards and below.
-They can be ordered at the same time. Since you're in South Korea, it would be more efficient to ship them together as well.
-when it says, "must be within", it just means that it needs to fit within those dimensions because that is the maximum space available. A smaller card will work.
The Sapphire Pulse RX 580 should fit, but it will be a very tight fit. It looks like the manufacturer is excluding the backplate from the thickness measurement, so it looks to be about 43 mm thick instead of 40 mm. Do you already have this card, and is the backplate removable?
@AseDen Would you kindly provide the dimensions of the CPU block and radiator of the 645LT?
As long as it's dual slot it will be fine.will zotac 2070 super mini fit the velka 7 case. i dunno which dimension should the cable space be counted in.
Has the pre-order stage already happened for the new line of Velka Cases? If not, I am wondering when I will be able to order a new Velka Case. Also, I saw there may be a continued production of the old 1.2 revision of the Velka 3 which interests me the most, and was wondering if any new information has come of that?
Anything but branding! The pure clean all uninterrupted black is partly why I have fallen in love with the Velka 3. And just like that there is no way I'll plug in the power led headers of the power button to the motherboard.perhaps any hole or imperfection used as an anchor for anodizing could be covered by a Velkase branding/logo? Added benefit of increasing brand awareness.
Just a thought. Keep up the fantastic work.
@VELKASE Michael I appreciate you posting more pictures on the site of the new cases with hardware inside. Do you have more pictures with the side panels off to get an idea of spacing inside with hardware installed?
Also, understand the CPU cooler height recommendation for the Velka 3 is 37mm yet ran height limit is 42mm. What is the actual clearance? Is there a lot of turbulence with an L9A cooler?
Will the Velka 7 support triple slot GPUs and can it be ordered without the PSU?
I'm intrested in buying the velka 7 but dont know tht does it deliver to india and if does for how much... I'm intrested in buying it in the july batch
On your website in the velka 7 section, it is written that the supported gpu dimensions are
289 x 43 x 135 mm (L x W x H)
289 x 40 x 140 mm (L x W x H)
262 x 40 x 145 mm (L x W x H)
So my 1st question is that does this include the power cables in it. My second question is that does the GPS need to be exactly of these specifications or less than the given ones.
Must be within one of the following dimensions including cables:
Note: power cables require about 16 mm clearance
I am kinda confused how you will manage the gpu IO in the velka 7 as the gpu is vertically mounted and the the io will come on top but in the images it is shown its at the back... I'm new to sff cases so thats why I am asking such questions.
The price seems reasonable. How much shipping did you pay for that?Enhance ENP 7660B 600w Flex ATX 1U Power Supply l Black Silent ITX Platinum PSU | SFFTEC
Enhance ENP 7660B Pro is a custom 600w Flex ATX power supply developed by SFFTEC. This powerful 80+ Platinum PSU is manufactured and customized by Enhance with a quiet fan, black short cables, and dark body. It fits neatly in most SFF PC cases, and will have a very limited stockwww.sfftec.com
There is a black enhance 7660b psu too. I have ordered this one for the Velka 3. It's yet to arrive but the case is also yet to be ordered.
I have ordered it april 2.The price seems reasonable. How much shipping did you pay for that?
This is one of the reasons I settled for the Velka 7 instead, the flex PSU market is somewhat uncertain right now.I have ordered it april 2.
I did pay 30USD to ship to middle Europe, Hungary but back then the unit did cost 129USD not 139USD.
It's still not shipped yet but the lead time is June so they still got half a month to do so.
I just hope the Velka 3 and the 7660B Pro comes around the same time so I won't have to wait for the other. ^^
