They do exist, finding one for sale seems to be another matter.Perfect timing! I was about to buy the one off Amazon in anticipation of my Velka 3. Now I just need to find a 2060 Super ITX. Which doesn't seem to exist.
I've been searching daily for that or the Gigabyte. That Zotac mini keeps popping up which is driving me nuts because it's too long. I'll probably settle for a 1660 Super.They do exist, finding one for sale seems to be another matter.
I found this too with the black ridge, you can easily turn the screws to a point where the motherboard has completely bent without feeling any resistance. I'm sure I was half a turn away from cracking my motherboard when I realised. In the end I removed the cooler and modified original am4 backplate (by cutting of the standoff parts and drilling the threads). This has stopped the bending and has enabled the cooler to be tighty fitted to the CPU. I found it has dropped temps by about 3c tooUnless you want to completely rebuild the system, I would hold off... I made that mistake, and it was tedious. Although I will say that building it a second time helped me to rethink my wiring and improve airflow. Also keep in mind that depending on your motherboard, the black ridge mounting may bend your PCB a bit. I have an AM4 motherboard
I won't be surprised if next-gen cards all have Thunderbolt 3 ports. So I don't know about double HDMI. I'm surprised they still have DVI on so many cards.There are no ITX 16 or 20 series cards with 2 HDMIs eitherGood excuse to skip this gen though and see what the 30 cards will bring. Hopefully they have HDMI 2.1 and it makes sense to have more than one again. If not I'll give up to carrying a dongle but I'm not ready just yet...
If you happen to have documented the process, that would be really helpful for those of us who seek such solutionsI found this too with the black ridge, you can easily turn the screws to a point where the motherboard has completely bent without feeling any resistance. I'm sure I was half a turn away from cracking my motherboard when I realised. In the end I removed the cooler and modified original am4 backplate (by cutting of the standoff parts and drilling the threads). This has stopped the bending and has enabled the cooler to be tighty fitted to the CPU. I found it has dropped temps by about 3c too
I took some photos of the end result for a friend, no photos of it fitted unfortunately. I was going to make a full post about all the mods I had to make to the black ridge due to my "OCD" but I'm away on work for 2 weeks. Anyway you should have a general idea of what to do.If you happen to have documented the process, that would be really helpful for those of us who seek such solutions![]()
www.asus.com
Do you have a PSU on order?Why do you need 2xHDMI ? when you can have 3 x DP
My Velka 3 build is almost ready final piece of the puzzle is the PSU ...
Now I need to focus on my Velka 5 build![]()
www.sfftec.com
I don't know why everyone hype the case so much. The quality is just very bad and everything else too.
3 rivets were broken, paint off.
The case isn't worth $50 in my eyes.
Have fun with the junk... mine is sold.
Looks like the manual has been updated with info about this.Is it possible to fit something (maybe "L" bracket) in here, to secure the gpu? I saw the custom internal piece, but space is kinda luxury in this case.
