Velka has posted that any motherboard with an integrated i/o shield will not fit in properly.
Hello.
I know that this already was discussed here but i wanna know if i can fit the geek modular psu with this slim button that have less than 13 mm on the inside part on velka 3 without modding anything. I´ll post the link of aliexpress of it.
0.88US $ 25% de desconto|12/16/19mm mirco interruptor curto curso momentâneo de aço inoxidável auto reset à prova dwaterproof água metal interruptor de botão de alimentação led luz|Interr.| - AliExpress
Compre Fácil, Viva Melhor! Aliexpress.compt.aliexpress.com
Sorry if i am repeating things...
Thanks!!!
@x01 - I have an ASUS Republic of Gamers Strix Z390-I and it does not fit in Velka 5... unfortunately - I am trying to fit it in the Velka 3 but I do not have a flex compatible power supply (I thought I have one but seems it doesn't have a CPU power
connector and my cables are too short - I tried to repurpuse a flex PSU) so I need to buy a new flex PSU.
later edit: I just now verified the incompatibilities even with Velka 3:
1. the motherboard is still hitting the front part of the case when installed (you need to unscrew the top back screw (and slide the front part between the stand off and the back part of the case - not a huge deal but still
2. the cpu mounting screws (Noctua NH-L9i) are hitting the PCIe connector of the extension cable, not allowing for the extension cable to be fixed-in/secured intro place with the included set of screws, I used longer ones ... unfortunately this makes the GPU a little bit flimsy (I didn't figure it out yet how to overcome this issue, maybe some washers again can save the day)
3. due to issue nr 2 corroborated with a possible width issue of my gpu, the gpu fan was hitting/scratching against the side panel (I had to use 1mm washers to clear it) not sure if this can be considered a "fix" but is a "for now" solution.
My reco: DO NOT USE the Z390i ROG strix from ASUS to build in any of V3 or V5 ... too much of a headache.
Is there a list of compatible hardware with Velka cases ? seems to be a little more "restrictive" compared with other SFF's
PS: @VELKASE Michael - I hope you will consider the above as constructive criticism not bashing the case at all![]()
Also I know that the updated manual for the newest revision of the Velka 3 states that in dual slot configuration it can support a total cpu cooler height of 37mm, however it also states that the max ram height supported for dual slot is 45mm. So, will the extra 3mm to turn the cpu cooler height from 37mm to 48mm with the NF-A9 PWM fan fit with side panels attached?
This inquiry about cpu cooler fan support is based on my idea for a future build in a Velka 3
Components include
Intel i9-9900KS CPU (delidded and plan to run stock)
Noctua NH-L9i Chromax Black CPU Cooler
[SNIP] Noctua NF-A9 PWM 25mm Variant Chromax Black Fan (for NH-L9i CPU Cooler)
Will the Black Ridge with the A9x14 chromax fan fit in the Velka 3 with a dual slot card?
