I have 80mm fan, but thickness is 10.8mm. Is compatible?
Which model is this ??
Not a problem because my power supply's fan is louder.Noise performance ?? - I read they were loud
-> This is a video clip to test that NVME m2 temperature.I have a question of the your riser cable for GPU.
Currently I am thinking of install a NVME m2 (adata sx8200) on the motherboard which can run at 85C at maximum. And the riser cable will be running over the NVME m2.
It would not touch the NVME m2 directly but it would be over it around 2-3 cm high.
In that case, will the cable could be safe from the heat caused by NVME m2?
I will appreciate it if you can advise it.
With only 2 top screws securing the PSU, is it secure with the case positioned upside down or moving around in transportation? Could there be more PSU mounting points in future iterations?
Would it be unrealistic to hope for some kind of optional top-hat/cover for the Velka 5 which helps hide away the cables sticking out the top? It would add to total volume of the case but it would make the build look so much cleaner and should be quite easy to make and mount/dismount.
It could come in the same or an accented color which could add even more to the overall looks. It could also come in an L-shape going down the back which would make it possible to route cables down the the bottom of the case for an even cleaner look.
For me it works like this, unscrew backplate IO shield and plastic deco and the small standoff on the back (under the backplate). Swap the standoff (as shown in picture 1. 2.) against a M3 screw and with it the IO shield simply holds by pressure.
@VELKASE Michael
Building on one of the review comments of countersunk panel screws.IIRC you mentioned it was tried and failed.
Is it not possible just to increase the diameter of the hole in the side panel so the screw head sits deeper in the panel.
Since we have threaded inserts I assume the pressure of the screw head against the panel will stop it from moving ??
Maybe use flathead screw rather than a countersunk one
Please correct me if I misunderstood the original reason
Will it be possible to do the VK-5 type mount/vent options on the VK-3 back panel ??
Those holes will be turned into slots.
