Nu2SFF
The NH L9a; as far as I'm aware that's the only heatsink that will fit in the VK-3. I currently have overclock disabled in mine, what about yours?
For the 3600, the Jonsbo HP-400 is a better cooler for lower temps than the NH L9a
sid21177
170
27
The possibility of support for DC-ATX power supplies with external AC-DC adapters and 2 mm extra maximum graphics card length. There will not be any changes to existing features or the current appearance of the case yet.
Please do consider slits instead of fixed HDD holes on the rear L-panel
ondert
349
165
Does it fit inside Velka 3?
edit: ok, found it. 36mm height, looks promising. I was wondering if it could be enough for 3700x.
Nu2SFF
It's enough at stock for sure because the 3700X is a 65W TDP. How much are you looking to overlock?
ondert
349
165
Overclock? Nooo, I have no intention of overclocking, in reverse, I think to undervolt a bit. 3700X seems a bit more than 65w chip. So, I have read that NH-L9 struggles to keep the chip under 80 celcius degree. I was looking for a better cooler at the same height.
DeXeD
Hello together I'm new here in the forum. I am waiting for my Velka 5, it is the customs in Germany.
I have a 3700x with a Cryorig C7G running at 4.1GHz at 1.175V to about 75 °C.
Reactions: ssun
smitty2k1
978
501
How much vertical height is there in the Velka 3's power supply area? I know the FlexATX is 40mm tall, but is there an extra couple mm down there for say the Meanwell 400w RPS-400-12-C (43mm with case supposedly).
Reactions: Windfall
VELKASE Michael
VELKASE
Oct 7, 2018
743
914
41.5 mm from the bottom of the case to the edge of the motherboard tray. The riser needs about 1 mm.
VELKASE Michael
VELKASE
Oct 7, 2018
743
914
Website is back up. Case descriptions are more detailed, there are 3D models that can be rotated, and there is now a separate pre-order page.
