I was in on the September pre-order and received my Velka 7 today! Some thoughts:
The case is sturdier than I thought it would be. The edges/corners having the steel poles is awesome, they definitely make this thing feel solid. The powdercoating/painting or whatever on the side panels is pretty nice, but one of mine had a few tiny imperfections. You can feel them if you run a hand over it, like some small bumps/sharp points sticking up. You can't actually spot them without running your hand over first to locate their exact spot, then looking very closely. Overall the cosmetics of the case are VERY good. Having owned the NFC S4M Classic and the Skyreach 4 Mini, I can say this one is closer to the S4M Classic in build quality/attention to detail than the Skyreach, but still I am very pleased!
I expected building in this thing to be very difficult based on some other peoples' posts. I can say that was not true at all. I built the whole thing in just 1.5 hours, and that includes disassembling my Skyreach 4 Mini.
I am using a Zotac 1660 TI Amp video card for now until more cards are in stock. It is short enough for the SSD's to fit under the video card. I placed 2x 3.84TB Samsung SSD's there(a 3rd can fit if you wanted) and a 5TB 2.5 HDD on the other bracket. I noticed that you could technically add another 2.5 drive on the other side of the bracket(middle of case side). There are no mounting points and this compatibility would depend on your PSU(because where the modular connections are). This could be advantageous for anyone who wanted to have some MAJOR storage in a small case like this. I run a 2TB M.2 NVME for boot drive, but imagine putting a 2x M.2 / 1x thick 5TB 2.5 HDD / 4x slim 4TB SSD's....... You could literally have like a 25+TB build if desired. Maybe there could be a small revision in the future to add mounting holes for this config.
I really wish the PCI adapter had a way of folding a little bit flatter, but I can say it's definitely durable. I bent mine very flat with the double bend(wish there was a way to do a single bend) and it held up just fine. Very solid piece honestly, just wish it could be flatter, as it puts pressure on the backplate of the video card and makes it closer to the side panel than it really has to be. Maybe an adapter like the one that comes in the refreshed Ghost S1 will be a future swap/test for me, because I think that one would be a little slimmer(since you can twist the individual wires). I however don't know if the mounting holes line up. Once that case comes in, I'll do some testing.
When it comes to routing the Displayport/HDMI connections, I recommend folding the displayport ones downward and under the connection, and the HDMI upward and over the connection. That won't make sense until the case is in your hands, but once you see the DP ports stick up far enough to fold under the connection, you'll understand. This made my top ventilation actually functional. Still only slightly though.
When securing the video card, the flip out tab that you fold back to secure the card in place was weird. It felt super janky at first, and I didn't like that technically the screw holding it in gets loose when you rotate it to secure the video card. However, once it's flipped back in place, it secures the card very well, and lined up perfectly. I believe if this piece was held on with a rivet or screwed from the other side that would be better. Some kind of attachment that would allow it to rotate freely. Simply because I had to tighten the screw back up by holding the threads with needle nose. You have to do it that way because the screw head is covered by the MOBO which you install first.
My case front panel is currently not closed, because I have an Aorus X570I Pro WiFi. I can't get it to close and I don't want to cut my cables, so I will reach out to Michael to see if I can get one of the new front panels.
The front panel button is amazing. Great tactile feel and nice illumination while being super slim.
I will probably get custom cables for this in the future, but even if you don't want to spend the money, there is plenty of deadspace in the bottom front of the case to tuck away all the extra and not affect airflow at all.
Overall, I absolutely love it. It is my new favorite SFF case for sure. I mean overall I think my NCASE M1 is still the greatest case of all time, but this is less than half that size with very good compatibility. The quality is great at this price, especially for a low production case. The vertical standing orientation makes this case an absolutely amazing design that takes up very little space. It's like an NZXT H1 but not gigantic hahaha! Also the black ridge cooler, with a fan UNDERNEATH runs quieter than my Skyreach 4 Mini. Incredible job Michael not only on the design of the case, but with communication/delivering a product that exceeded expectations!
Specs:
Aorus X570I Pro
Ryzen 3700X (Going to swap to 5950X in the future)
Alpenfohn Black Ridge Cooler with Noctua Slim 120MM Fan below (intake orientation)
32GB 3600MHz CL17 VLP RAM
Zotac 1660 TI AMP
Corsair SF750
Samsung M.2 2TB
2x Samsung 3.84TB SSD's
Seagate 5TB HDD
