Prototype SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
duynguyenle
331
331
Not been checking the forum for a while but just saw this in the recent store newsletter. I like the design but my personal feeling is that 50mm for CPU is a bit too restrictive and limits you to basically 2-3 main options like the Blackridge or the AXP90-47 (especially when there are some highly compenent coolers around the 67-75mm mark) from ID-Cooling, Thermalright and Noctua and the likes.
Even at 58mm there's some good options like the ID Cooling IS-50 or IS-55 or the Scythe Shuriken 2. I'd like to see something similar to this but trade a bit of volume for better CPU clearance (maybe a halfway between the current iteration and the P-ATX)
SkorpioNElite
That would be a complete other case class. P-ATX I think. 50mm CPU cooler height is enough for 65W CPUs or better CPUs limited to that number (AMD Eco Mode).
Coolers are also available, of course not as many.
The classic Noctua Small Form Factor coolers for example.
Or this one https://www.bequiet.com/de/cpucooler/3992.
I'm currently using the Pure Rock LP in the Sentry 2.0 and it works quite good.
L91
64
73
www.youtube.com
In all tests I've ran on AM5 and LGA1700, the AXP90-X47 FC outperforms the IS-55 and is only slightly worse than BS3 and far better than L12GE. This cooler punches well above its weight class. Not sure if it fairs quite as well on AM4. 50mm clearance is completely fine.
Reactions: HWI and Atlas
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Hi, thanks for the feedback!
I was considering this, but after giving it some thought I concluded that it would be too close to the P-ATX to differentiate it from it, and you would only get maybe slightly better cpu cooling as L91 said, and wouldn't gain much for the GPU since it can already fit 3slot models and wider ones are also longer than 305mm so I would also have to make it longer, which would bring it even closer to the P-ATX.
Main goal for this one was maximum space and weight savings, and I may have overdone it but we'll have to see! Hiting the 7L mark with this compatibility wasn't easy.
SkorpioNElite
You promised some pictures ;) ... Any kind of release date for us?
Currently your competitors are merely the Sentry 3.0 (Maybe Mid 2024) or the cosole-case-style Velcase (Maybe Early 2024).
Apparently there won't be a new generation of graphic cards for some time.
And the 4090 fits in your case just fine.
Some updates?
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Some updates?
Got the prototype, and still testing it, here are some teasers:
Atlas
Very impressive, good work!
I welcome your decision to not have any front IO.
Do you include a 4.0 compatible riser?
What do you think is the optimum 12VHPWR custom cable length for the RTX 4090 FE?
Please keep us updated.
I can't wait! 😵
Reactions: HWI
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
I can't wait! 😵
Hi, thanks, glad you like it :)
There will be gen3 and gen4 options. For the cable something like 15-20cm should be enough.
Reactions: Atlas
SomeRandomDeafDude
37
23
I feel insane asking this- but here goes.
Would it be possible to do a full watercooled build in this with: 12600K+MSI Ventus 2x 4070 watercooled(waterblock permits it to 171mm long), with a single 240mm radiator+fans, and a HDPlex GaN 500W? I'm not sure how I'd lay everything out, but I can say this: GPU under motherboard, motherboard in typical spot, radiator on right of everything and 500W GaN on top of case or somewhere else within the case. I'm just dabbling with a thought, that's all.
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
ok I just checked, it could tightly fit behind the GPU if it is one slot thick and has a backplate
Reactions: Akieza7 and Atlas
