Production SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
I think axp90 x47 copper can handle the 9800x3D with AI overclock and if you turn on Turbo mode, even cooler, without decreasing TDP. Currently using it. Altough I hace my PC opened without cover. Maybe it is more noisy and not so cooler if you close it but still, I think it if you can handle noise if better perfomance for the cpu.
If you use it for rendering it might be different but otherwise…
In fact there are, at least, 2 factors to differentiate.
CPU cooling : stand alone
In fact, AXP90X47 copper is performing in a similar way as the IS-47-XT, even if the AXP90-47 Cu is slightly better (but no a game changer). However, none of them is able to handle the R7 9800X3D at full load (IBT2.54 or Cinebench) even with -30 Curve optimiser/shaper. They are both reaching stock thermal throttle at 95°C of the CPU. Here is a table with the results I got while stressing the CPU alone, with variable TDP
CPU cooling : Gaming with GPU thezrmal interference
Even with the RTX 4080 Founder's Edition, there is some hot exhaust air from the GPU interfering with the cooling on the CPU. Fan duct (Noctua NA-FD1) + combined with quieter fan (Noctua 92 slim 2200rpm version) I have installed is helping on this specific point, more than I hoped.
Basically with Noctua Chromax 92 slim 2500rpm I was able to reach 95W TDP (CPU stand alone, max fan speed, very noisy) but only 75W TDP with gaming load with tolerable noise.
With the Noctua 92 slim 2200rpm + Fan Duct, I was able to reach, barely, 95W TDP, but while gaming, I'm able to reach 88W TDP with gaming load with tolerable noise.
Overall my second setup (Noctua 92 slim 2200rpm + Fan Duct) is the worst absolute performer but the best in real life..:D
I will also try using AMD PBO to fix the temperature limit, but leave power PPT by default.
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Not quite, that's the Fractal Design Node 202 style layout. Been around for almost 10 years.
Inspired from Node 202 but only 7L vs 10L (Node 202). It is similar from P-ATX to U-ITX.
However, it seems to be limited only to 2 slots GPU, unlike U-ITX, with 3 slots compatibility.
morj
366
698
Germany
"Inspired from Node 202 but only 7L" yeah, this too has been done here https://zaber.com.pl/sentry/ in 2019.
Not to throw shade at U-ITX, just saying that it's a different layout.
Reactions: riba2233
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Anyone figured out if a 9070xt card will fit?
There should be some models that fit yeah.
Yes I searched for versions here is a first list (not exhaustive!) of RX 9070 XT of compatibility with the U-ITX :
RX 9070XTDimensionsU-ITX
(306 x138 x 60 mm)
Asus RX 9070 XT Prime312 x 130 x 50 mmNo
Asus RX 9070 XT TUF330 x 140 x 62.5 mmNo
Asrock RX 9070 XT Taichi330 x 140 x 61mmNo
Asrock RX 9070 XT Steel Legend Dark298 x 131 x 58 mmYes
Sapphire RX 9070 XT Nitro +330.8 x 128.5 x 65.68 mmNo
Sapphire RX 9070 XT Pulse320 x 120.25 x 61.6 mmNo
Gigabyte RX 9070 XT Gaming288 x 132 x 56 mmYes
Gigabyte RX 9070 XT Elite339 x 136 x 59 mmNo
Powercolor RX 9070 XT Red Devil340 x 132 x 69 mmNo
Powercolor RX 9070 XT Reaper289 x 111 x 41 mmYes
Powercolor RX 9070 XT Hellhound327 x 128 x 49 mmNo
I have checked RX 9070 XT from Asrock, Asus (a shame RX 9070 XT prime is a bit too long), Sapphire & Gigabyte.
MSI didn't announce yet anything.
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Also some powercolor models, thanks for the list :)
And some will fit with the offset mask, ones that are 306-326mm long and not wider than 62mm.
Good point, about this offset of +20mm, how does it look? There is a clear gap with the front panel? Do we need specific new side panels?
I've updated the list with powercolor.
XFX is also doing some RX 9070 XT, but they are all 3.5 slots but no details on final dimensions.
Mosskovskaia
70
34
I think there where some standoffs in the package but I’m not sure if they are used for a 2 slot card and you have to buy some if you also want to use them for the front panel. They come with the case and, as far I understood, you can „offset“ or widen the gap from the frontpanel. This leaves a little gap, 2cm or longer if you need more, but you can fit longer gpu. It’s up to you if this will be something you want or you want to retain the compactness of the case.
Edit: I found the xfx cards but not that they are too wide they are also too long 350mm+.
Reactions: MarcParis
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Yes they are the same standoffs used to offset the 2slot gpu but you will probably never use them at the same time, as I doubt there are any true 2slot gpus longer than 306mm that people still use.
It just offsets the front mask, everything else stays the same. It might not be the best solution aesthetically, but it will probably better than nothing for some users :)
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Thanks!
Then it is as I udnerstood from the manual. Not the most aesthetic but could be convenient, for example to fit a RX 9070 XT prime with 5/10mm front offset..:)
In that way, it is also possible to add 4-5cm to fit long 3 slots cards...but I have big doubts on the final look...😎
Reactions: riba2233
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Here is updated GPU compatibility lists (RTX 5080/5090/9070XT) for the U-ITX :
RTX 5080 CardsDimensionsU-ITX
(306 x138 x 60 mm)
Asus RTX 5080 Prime306 x 126 x 50 mmYes
Nvidia RTX 5080 FE304 x 137 x 40 mmYes
MSI RTX 5080 Ventus OC303 x 121 x 49 mmYes
MSI RTX 5080 Inspire288 x 112 x 50 mmYes
Gigabyte RTX 5080 Wind Force OC304 x 126 x 50 mmYes
MSI RTX 5080 Trio OC338 x 140 x 50 mmYes with 40mm offset panel
MSI RTX 5080 Suprim SOC359 x 150 x 76 mmNo
MSI RTX 5080 Vanguard357 x 151 x 66 mmNo
MSI RTX 5080 Shadow303 x 121 x 49 mmYes
Gainward GeForce RTX™ 5080 Phantom GS331.9 x 145.6 x 69.9 mmNo
Asus RTX 5080 TUF
348 x 146 x 72 mm
No
KFA2 GeForce RTX 5080 1-Click OC315 x 140.5 x 50.7mmYes with 10mm offset panel
Gainward GeForce RTX 5080 Phoenix331.9 x 133.1 x 60 mmYes with 30mm offset panel
Zotac GeForce RTX 5080 Solid OC329.7 x 137.8 x 67.8mmNo
PNY GeForce RTX 5080 Triple Fan OC330 x 60 mmYes with 30mm offset panel
Inno3D GeForce RTX 5080 X3 OC300 x 120 x 50 mmYes
Asus ROG RTX 5080 Astral
357.6 x 149.3 x 76 mm
No
Palit RTX 5080 gaming pro331.9 x 127.1 x 60 mmYes with 30mm offset panel
Palit RTX 5080 gamerock331.9 x 150 x 70.4 mmNo
RTX 5080 GAMING OC 16G340 x 140 x 70 mmNo
RTX 5090 CardsDimensionsU-ITX
(306 x138 x 60 mm)
Nvidia RTX 5090 FE304 x 137 x 40 mmYes
Asus RTX 5090 Astral
No
Asus RTX 5090 TUF
348 x 146 x 72 mm
No
MSI RTX 5090 Ventus325 x 139 x 67 mmNo
MSI RTX 5090 Trio359 x 149 x 70 mmNo
MSI RTX 5090 Vanguard357 x 151 x 76 mmNo
MSI RTX 5090 Suprim359 x 150 x 76 mmNo
Gigabyte RTX 5090 Windforce342 x 150 x 65 mmNo
Gigabyte RTX 5090 Gaming342 x 152 x 70 mmNo
Gigabyte RTX 5090 Master360 x 150 x 75 mmNo
Inno3D RTX 5090 X3333 x 137 x 60 mmYes with 30mm offset front
Inno3D RTX 5090 iChill X3334 x 148 x 73mmNo
Zotac GeForce RTX 5090 Solid OC329.7 x 137.8 x 67.8mmNo
Gainward RTX 5090 Phantom331.9 x 145.6 x 69.9 mmNo
Palit GeForce RTX 5090 GameRock331.9 x 150 x 70.4 mmNo
(306 x138 x 60 mm)
Asus RX 9070 XT Prime312 x 130 x 50 mmYes with 10 mm offset front
Gigabyte RX 9070 XT Elite339 x 136 x 59 mmYes with 40 mm offset front
Powercolor RX 9070 XT Hellhound327 x 128 x 49 mmYes with 25 mm offset front
Mosskovskaia
70
34
Well in Germany the launch was a complete shit show. Bots bought every stock immediately and now they are reselling them on eBay für 1200€. I’ll stick to my 1070 longer than I thought but I’m. Or going to spend this insane money on a GPU.
Reactions: Akieza7
Akieza7
39
In France it was a little bit better there were some overpriced model available at launch (like 880 for the 9070 xt) but getting the msrp ones was impossible.
It is still possible to get it for some models around 880
I decided to buy the regular 9070 since I was able to purchase it at msrp 630 euros it was available for around 2 hours before getting out of stock I think it is decent value and I didn't have to overpay
Mosskovskaia
70
34
Actually it was the same here but I can’t get myself to pay that much for a GPU…
Akieza7
39
I found a decent one at a smaller retailer
Then only deliver in France and belgium unfortunatly
They also have a good msrp 9070
There might be a few other left on the web
Edit:
Nevermind you can't actualy buy them they just say that they will have stock soon
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
A pity, in France, it was clearly possible to buy at 3pm...a nice change compared to Nvidia RTX50.
However I'm surprised (pleasant & angry) that RX 9070 are sold out everywhere now...:(
