Then I understand it as a yes..Good question, it depends on the PCIe slot position. If it's in the 1st position, you can fit around 150mm tall gpu and if it's in the second then you should be able to fit a 130mm one. I will write all of this in detail once I release the full spec and compatibility list![]()
As usual, I would be curious about the cooling capabilities of this kind of setup.
