Production SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
sheltem
Here’s my build!
- AMD Ryzen 9800x3d
- Thermalright AXP90x47 FC with Noctua A12x15 fan mod
- Gigabyte Windforce 5070ti SFF
- Corsair SF1000
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
Here is a thread with U-ITX+RTX 5090 FE...
It seems working well (RTX 5090 FE undervolted at around 500W) and reasonible noise (<50% fan speed).
Basically pasthrough GPU are the best GPU type for the U-ITX.
InspectorClousoe
Which cpu cooler is that one? guess you get a better cooling than thermalright axp90-x47 cooper, but is that cooper or granite or just a non as good those metals? which cpu fan would you use? how many mm in total? wonder if it will fit my asus b650e-i.
If you want to get red of those cables it might help to order a cable for rtx4000 as I did on cablemod. quite expensive tough.(50-60eur? cant remember) for one cable that is 2 x PCI (corsair) to the 12pin (12? cant remember) so you dont need to those extra big size adaptors. altough you need to have 3cm straight from the gpu. on mine is hard to see but I got it hardly.
EDIT: I just saw, your gpu conmector is oblicuous , so the 3cm straigh might be not possible or if so, just after needs to turn in a high angle which maybe is not recommended.
Reactions: MarcParis
MarcParis
Apr 1, 2016
3,930
3,085
FRANCE
In fact it is not my personal U-ITX setup, just the first example with a RTX 5090, double passthrough fans, that seems effective within the U-ITX
The CPU cooler is the Alpenfohn Black Ridge (designed by DanCase). Originally it was only compatible with AM4, not AM5 (except by removing AM5 socket). As far as I understood we can tweak by updating AM5 backplate from Thermal Grizzly (https://www.thermal-grizzly.com/en/backplates/s-tg-bp). However you can get full cooling potential with 120mm fan, pretty hard with VLP RAM. More details in this video.
Regarding the RTX 5090 FE connector, it is well oriented (angled) but the connector remains straight.
The true issue of this build is related to rarity of the RTX 5080/5090 FE models, hands down the best SFF GPU as they are orienting exhausted air...pretty scandalous
marianairam
It really is a great case.
I want to use it without the included stand and was wondering if there is a recommendation for anti slip pads for the bottom of the case. I tried using some rubber feet but they make the case quite unstable, so using some long rubber anti slip pads might be the better option. Any pointers?
Reactions: riba2233
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Hi, glad you like the case!
Would you just like for the case to be lower overall or is the stand too wide for your use case? Or you just don't want to carry another piece?
I can think of a solution based on your constraints.
