Prototype SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
dc443
75
28
RTX 5090 FE is nowhere in sight... neither are any of the AIB models. That is what's putting my build on hold right now. I'm willing to contemplate a case like @riba2233's MNLT to drastically ease the constraints on CPU cooler and PCIe5.0 riser, I do think a build with that and 9950x3d or future zen 6 16 (24??!) core X3D SKU would be epic, though I haven't even looked into whether it's remotely realistic for any AIB 5090 to be able to fit into one.
There is one b-stock MNLT in stock that I can see! But I'll hold off because the availability of the GPU and the DLSS4 transformer upscaler release has really breathed some more life into my existing system.
As to the above back and forth about U-ITX's ability to handle heat... I don't think there is necessarily any misinformation, i think people just have huge differences in what "acceptable noise" is.
Ever since I became an SFF insane person, I have been willing to drop volume at almost any cost, which includes temps and noise, and that does mean my 3080Ti velka 7 is actually screaming loud in its standard configuration, that is, no extra fans bolted on the side of the case to force feed the GPU. @MarcParis was mentioning at one point 1400rpm on the 4080 being an issue, bro... 1400RPM is whisper quiet... When your temps are shooting to 90 within a minute at 1400RPM you're a lot more willing to crank more RPMs to keep them in check.
As his post also demonstrates, the 1400rpm 65C temps on that 4080 only rise to low 70's C at 1100RPM. That's ... that's in a far away galaxy compared to my 3080Ti flirting with 90C at stock trying to suck in air through the side panel without added high static pressure case fans bolted on top of it. The stock fans max out over 3000 RPM. They get LOUD. Now given those numbers, that 4080 could probably survive at 600 RPM staying in the mid 80's C pushing those 300W... that triple slot FE cooler is a real beast. What is important to understand is that Marc's recommendation to keep the GPU under 250W is under a very strict noise limit for comfort reasons. But some of us are doing SFF because if it isn't under a certain size, we can't bring the rig with us on trips. In most cases I do not care one bit that it is loud, and it is still not nearly as loud as a high end gaming laptop. I would say something like I have my closed back headphones to use, but the truth is that those headphones are far too bulky as well to consider bringing on a trip. Luckily, airpods pros have got this covered, and are a necessity for the airplane anyway.
Sure 5090 will push more heat and sit at a higher temp compared to 4090, but with how thin it is, we'll be able to do lots of things, like space it appropriately away from the panel so it can suck more effectively, and we can do some ducting to keep the flows separated from other components. Not directly blowing its exhaust on anything other than a side panel with lots of ventilation is nearly optimal, and I see essentially zero compromise. I don't have too many qualms pushing GPU core temp to low 80s C, and if we combine that with no upper limit on fan RPMs, I think it's clear the U-ITX is totally fine for a 5090 and should clearly outperform other competing SFFs by eliminating things like exhaust air blasting mobo/SSD, mixing with CPU intake, and so on. When noise is an issue, a healthy undervolt can bring it to a fully tamed 400w power level without losing too much performance. I very much doubt I will find need for bolted on case fans to augment airflow if I do a 5090 U-ITX build.
Anyway what I'm very interested in w.r.t. the U-ITX would be in exploring changing the GPU's orientation to prevent routing the riser near it to maximize flow-through cooling, it's only a need for the 5090FE but a good enough solution might be practical for other high power components such as 4090FE as well. If you have a high quality silicon 4090 it is known to get 10 or even 15% more performance if you pump 600W through it!
From what I can see depending on mobo geometry, such a mount:
may be possible as well, but that will need to move where the PCI bracket will be mounted on the case, which is getting into questionable territory already (not to mention I suspect the PCIe power may impact the PSU with the card shifted over that far). I think the way to go for the U-ITX at least will be to still use a flexible (but very short) riser and do whatever it takes to make the PCI bracket fit into the frame when the card is flipped over.
I keep going back and forth on this but another avenue for 5090 build may be an open build like the xproto, the footprint of a sandwich vertical case is optimal. This property has turned out for me to be one of the velka 7's most delightful features. BTW the adhesive of the rubber feet it came with melted off very quickly since the entire case reaches 50C by my estimation. Super glue did the trick. Still madly in love with my velka 7.
For portability for an open case, then, what i realized was that a custom fabricated protector case/shell may be able do the job, done carefully enough might even be durable enough for air travel, which is a path toward eliminating the single big drawback of an open design without panels. Then during operation we get the optimality of a full open bench setup without panels to impede airflow, and the possibility of also flipping the GPU to exhaust straight out the side provides an elegant space heater use case. During the winter I legitimately wish that my velka 7 had less impeded flowthrough so the warmth could flow at me more directly.
Still, U-ITX remains at the center of my crosshairs for 5090.
MarcParis
Apr 1, 2016
3,834
2,995
Fan speed is way not enough to judge noise as there are other major factors like fan size (dimensionning the motor), fan position (pull, push).
  • 1400rpm on a 92mm*25mm fan in open air==>whisper quiet (based on Noctua NFA9x25)
  • 1400rpm on a 120mm*25mm fan in open air ==>audible but ok (based on Noctua NFA12x25 Sterrox)
  • 1400rpm on a 140mm*25mm fan in open air ==>Annoying (based on Noctua NFA14x25 G2)
If you are adding pull setup creating air turbulence, you are increasing significantly annoying noise generation.
On my RTX 4080 FE, you have big, thick fan and 1 is in Pull setup generating some annoying noise from 1300rpm approx
At the end, my jugdement on a fan noise is how it can be distracting while I'm working/playing on my computer. I'm using a closed headset.
In the case of the U-ITX paired with a full stock RTX 4080 FE (reaching 1400rpm), the noise generated while gaming was clearly distracting me from my game and it was even very annoying. Without my tweak on the RTX 4080 FE fan speed (limit them at 1100rpm all time) I would have moved my build in another case the day after.
Like you, I'm still working/thinking how/what to put back my setup inside the U-ITX.
Back to the RTX 5090 in general, please watch below videos
From my personal point of view, I'm almost out of getting any RTX 5090, judging it way too risky due to its power distribution scheme (unbalanced currents).
Reactions: dc443 and riba2233
vinnyoflegend
156
102
Reactions: MarcParis
MarcParis
Apr 1, 2016
3,834
2,995
Regarding risers that block flow-through, I wonder if there's some combination of Oculink with 2 PCBs that could reduce cable width significantly.
Something like this adapter for the slot:
connected via Oculink cable (which is much more narrow)
to a port pcb like this but simpler, probably less power connectors (maybe 6p PCIE instead of 24p)
Could be a solution.
Another will be to adjust the U-ITX with a gen 5 riser with more space like this one below. By default it won't fit as the PCIe slot is taller than the U-ITX gen 4 riser.
https://fr.aliexpress.com/item/1005....0.0.30afrM4OrM4OEt&mp=1&gatewayAdapt=glo2fra
OziTwo
Upstate CNY here. I ordered during the first batch in December. Got my order in 8 days from first scan to delivery.
After First scan did you receive any more updates from the Croatian post tracking before the delivery happened? Like an “Out for Delivery” notification
vinnyoflegend
156
102
Croatian tracking had 2 more updates before it arrived in the US.
18.12.2024 13:37:00Wednesday
Item delivered
Delivery in progress
18.12.2024 09:46:00Wednesday
Item is out for delivery
At the Customs
17.12.2024 07:03:00Tuesday
Item returned from CustomsUSJFKA ISC NEW YORK NY (USPS)
17.12.2024 05:23:00Tuesday
Item sent to CustomsUSJFKA ISC NEW YORK NY (USPS)
In transit
17.12.2024 05:22:00Tuesday
Item receivedUSJFKA ISC NEW YORK NY (USPS)
11.12.2024 10:44:49Wednesday
Item sent10003 ZAGREB
11.12.2024 08:56:31Wednesday
Item received at exchange office10003 ZAGREB
Received
10.12.2024 13:09:06Tuesday
Item received51118 RIJEKA
USPS should also recognize the tracking number as "Origin Post is Preparing Shipment" initially. This (and the other Croatia EMS scans) populated after the first scan in NY.
After these scans, it was next scanned by my local regional distribution center.
Arrived at USPS Regional Facility
JAMAICA NY INTERNATIONAL DISTRIBUTION CENTER
December 17, 2024, 7:04 am
Inbound Out of Customs
December 17, 2024, 7:03 am
Inbound Into Customs
Processed Through USPS Facility
ISC NEW YORK NY(USPS)
December 17, 2024, 5:22 am
Processed Through Facility
ZAGREB 10003 EMS, CROATIA
December 11, 2024, 10:44 am
December 11, 2024, 8:56 am
Acceptance
CROATIA
December 10, 2024, 1:09 pm
vinnyoflegend
156
102
Aliexpress is spying on my brain, started seeing this today:
500, 800, 1000mm cable lengths should make it possible to route anywhere. It's horizontal rather than vertical though so would need to be secured another way but should fit fine. I'm not sure sure about that sata 12v adapter they provide though :D Probably better off feeding it 12v with a better connector.
MarcParis
Apr 1, 2016
3,834
2,995
I cannot access your link unfortunately..:)
dc443
75
28
@MarcParis I agree with you. My most recent 1400RPM experience is with 90mm and smaller fans admittedly because, well, that's velka 7 life for you.
Without a doubt a large fan with intake near a side panel will generate significant noise at such a speed...
The removal of power distribution sensing over the PCIe power wires is a very disappointing turn of events. As an enthusiast I would begrudgingly look into placing additional measures to monitor to ensure no wires become overloaded. It's totally unacceptable that they did that on the 5090, especially when so much care and attention was put into its cooler's design.
I'm just going to bide my time and set my expectations low. If I can obtain a 5090 before 2026 I'll be happy. And if I can wait for them to do a revision to add power monitoring, even better. 5080Ti with 24GB would be a sweet spot choice for a build but the incentive to get 32GB for various use cases is strong. even in games having that much VRAM already got a use case, if you throw DLDSR into the ring. Someone said on reddit that a 5090 should be able to drive DLDSR at 4K even with the monitor requiring DP1.4 DSC.
Well, it's not like i'll switch my monitor if i can't get DLDSR at 4K. What a nothingburger of a constraint that would be.
I love seeing more PCIe connectivity options! bring it on! Not needing to flip the GPU around, having to modify the case to do so, just to try to get optimal airflow, will be nice.
  • Love
MarcParis
Apr 1, 2016
3,834
2,995
you just need to change shipping country to the USA.
Thanks and it is working...even if I can't order it, I can see it..:)
Indeed this is an interesting solution!
Very flexible but more bulky as standard riser.
It depends on your use case. Could be useful to link the MB with external component.
InspectorClousoe
Well, please read my full review & experience inside the U-ITX, using an R7 9800X3D and RTX 4080 FE..:) (check my signature)
My comment about putting a RTX 5090 FE is based on experiment, not theorical.
Stating that a stock R7 9800X3D can be tamed by a 47mm tall cooler is totally wrong. You need to massively undervolted & limit its power. For some applications (like some games) it is ok, for others, you will limit performance.
Similarly I was obliged to block my RTX 4080 FE fans to 1100rpm, otherwise, turbulence & fan noise were simply too much distractive...without saying my back SSD was simply cooked by the GPU exhaust air (reaching 70°C doing nothing).
At the end you can even compare U-ITX vs N-ATX cooling/thermal performance :
U-ITX : https://smallformfactor.net/forum/t...9800x3d-and-the-rtx-4080-fe.19941/post-291355
N-ATX : https://smallformfactor.net/forum/t...n-atx-v2-complete-build-log.17997/post-291941
Don't get me wrong, the U-ITX is a great case and I love it! However it has its cooling limitation. Of course you can put a R7 9800X3D paired a RTX 5090 FE inside but you will have to undervolt/downclock them massively to avoid thermal throttling & huge noise.
As stated, my advice is to limit CPU to 65W and GPU to 250W inside the U-ITX.
I have a U-ITX type in 3D printed plastic since several years ago.
7800x3D 48mm (copper the thermalrigh x47 or something with a orange fan) 4080 Super zotac and I am using PCVR
there is almost no perfomance impact, I even do Overclocking to GPU and CPU
for gaming the cpu is not going to have issues unless you are not using a 5800x3D/7800x3D/9800x3D or ryzen 5 5600 7600X etc. you can handle a 13900K easily. Otherwise is fine!!
My 4080S works great. The only downside is fan RPMs but that does not mean throtling! Is just that it will be noiser. I am using headphones and the fan are opposite direction to me. So I dont care!!
I am always 100% to keep the higher temp as 67degrees.
On summer it will be always 100% as it is usually 72 degrees maybe 74 for a moment.
BUT I OWN a ZOTAC! Is the worst! If you use another card the thermal solution will be better.
And As I said, I am doing overclock. So lets say that on summer you need to play stock (not true) , quite far from what you said about 30% perfomance lost.
@riba2233
I am waiting for a restock of U-ITX as I did not discover it sooner.
You said something about magical trick that allows frontal panel to be off and use the pillars to use a larger than 306 gpu.
Is that still possible on your on sell product?
are there any compatible AIO gpus? I saw a tiny one slot 4090 that maybe allow to se a AIO for GPu. Just asking, it is a real challengue
I was not able to create my personal U-ITX 3D printed to methal, so I did not sell my version. Anyways a lot of challengues that I was not able to sort out. rtx 4000 connector was a real pain anyway, I had to buy a custom cable on cablemod (55eur) I am putting all the fans in the same direction (gpu / cpu / psu) so I had to use a PCI extension (cord) which was a real pain. Cable management too. It was very challenguing to fit all in smaller sice than you (only 123mm gpu)
So thank you very much for selling this case.
InspectorClousoe
Yo
@riba2233
Sorry I meant you cant handle a 14900k
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
@riba2233
Very interesting, thanks for sharing! I am preparing the next batch of U-ITX cases, they should be ready in about a month. Do you prefer black or white units?
Yes, that trick still works, you can see it pictured in the manual in GPU mounting section.
4090 with AIO unfortuantely not even close :|
Np and thank you!
InspectorClousoe
Np and thank you!
For me, white (to combine with ps5 controller and quest 3)
The 4090 ultra tiny with one slot AIO is out too? Damm , sure it is hard to fit. Anyways that one is very special card so I guess is overpriced as hell, probably no way to get it anyway. But I was curious.
cool! I did not find it on the buy section or anywhere. Actually that comment regarding magic trick I saw it just on reddit.
i remember now, regarding the special rtx 4000 cable , is because they had two/three adaptor to PSU PCiE + the 2/3 psu pcie adaptor so the cable volumen was HUGE and unable to respect the 3cm straigh. so I had to buy the cable to have 1 direct and tiny cable instead of “4/6 masive cable”
MarcParis
Apr 1, 2016
3,834
2,995
Np and thank you!
Black version here with reinforced panel screw threads..:)
Here is my third setup inside the U-ITX..:)
https://smallformfactor.net/forum/t...9800x3d-and-the-rtx-4080-fe.19941/post-292311
InspectorClousoe
I think axp90 x47 copper can handle the 9800x3D with AI overclock and if you turn on Turbo mode, even cooler, without decreasing TDP. Currently using it. Altough I hace my PC opened without cover. Maybe it is more noisy and not so cooler if you close it but still, I think it if you can handle noise if better perfomance for the cpu.
If you use it for rendering it might be different but otherwise…
Neathdrawls
275
516
Finally got all the parts in for the U-ITX build, which the case actually arrived last week.
Easy enough to build in, especially with a small GPU that I used, and premium feel as per usual.
Although I initially wanted to do an ATX board with a Flex PSU build in it, but it just wouldn't work.
All in all, another banger of a case!
Specifications
  • Processor: Ryzen 5 7500F
  • Motherboard: Jginyue B650I Night Devil
  • Ram: 32(2x16)GB Juhor 6000 MT
  • PSU: Great Wall TF850 SFX Platinum
  • GPU: Maxsun Intel ARC B580 Milestone
  • Cooler: Thermalright AXP-90 Full Copper
  • Storage: 1x Kingston NV2 1TB
