What motherboard do you have ?I was wondering if the IS60 would fit my motherboard or not, then I realize that if I change to the N atx, I would want to change motherboard as well
Crosshair impact was a mini DTX attempt to shrink all ATX into smaller size...but its additional card is way too tall..Currently I have a crosshair impact , there are some compatibility issue that arise due to the add in card system , such as not being able to bend tubes low enough for aio in certain cases , or being unable to mount certain cooler in a certain way
I am looking at x570 taichi for the N atx
Imo this is a good thing, I hate dust getting in from the top of my current caseThis seems interesting idea. I think you would need modifications to use current feet as placement wont match and you may need more clearance in height for thicker cables/connectors (HDMI, DP, PSU). Also small downside would be that in this case top of the case would be solid.
I agree here...I would like to know when the N-ATX is going to be up for pre-order as well. This case gives me everything I am looking for in a sff case. My wife almost ordered the p-atx case until she read this forum and saw this case, lol (she wants one for the living room). Now I want one to create a console style pc...
Personnally I'll wait for spring 2021 to see what I need to renew.Yeah I would like a gen 4 option as well if possible for the riser as I have a 3070 and im looking at getting a 6800 XT if im lucky
@riba2233 would you have any feedback/benchmarks done in horizontal orientation (either P or N, using standard air cooling) please? I would like to know impact on both GPU or CPU temperature. Based on my experience on Node 202, orientation was impacting noticeably temperatures. (After Cerberus-X temperatures were not impacted by orientation)
Thanks in advance!
I'm planning to use hifi stands feet with N-ATX horitzontal case...It will provide enough clearance (more than my SM550 that offers great bottom exhaust capabilities)I haven't done any tests myself, but CPU and GPU draw air from the same side, one that has full access to fresh air so I don't see any problems with that configuration, it should have the same thermal performance. Maybe some of my customers who use the case in that orientation can confirm that.
Only consideration is if you use AIO that exhausts air to the right side of the case, you would preferably use a bit taller feet for that configuration.
@riba2233 Let's wait for release of N-ATX case..Will you have some pre-production samples? It worked well for my pre-production Cerberus-X..
I am not sure but probably no, since I usually get the prototype really close to the final version, then just do a few small tweaks before the first batch. But not impossible if I see that it needs a bit more tweaking, we'll see![]()
Please don’t compare h1 vs N-ATX...nothing comparable.
To be honest, take required time, as anyway all new & enthousiast chips are unavailable. N-ATX is a great concept case.I really can't tell anything regarding certain deadlines, sorry!
