Production SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
vinnyoflegend
158
102
It’s funny how we all have such different ideas about the ideal dimensions. But I do agree the depth is close to a worthwhile threshold (of the 70mm and sub 70mm class coolers)
To go narrower would confine us to 40-50mm class coolers and not even fit SFX PSUs. Plus to fit a GPU we would likely no longer be able to accommodate mATX or ATX boards, which to me is still the greatest appeal of the SFFtime cases.
Reactions: riba2233
Akieza7
39
I actually wish he could make it WIDER for bigger CPU coolers, eg. the AXP120-X67, which has been a stellar performer so far, no matter if its on medium-tier intel (i5-13500), or high-tier AMD (7950X in 105W Eco mode and manual 120W mode).
cu, w0lf.
With how well a 65w cpu like the 7700 perform I don't think it's nessessary the goal is for this case to be small what's the point of another Fractal ridge? The added value of being 7L (fits in most backpacks super easy to carry inside a small suitcase ) far outweights the compromises that are being made. There is space for other cases with other purpuses but I think this one makes the most sens as a great small volume big gpu case
Reactions: riba2233
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
cu, w0lf.
I would have to make it 20mm wider, in which case it would be just 0.5L smaller than if I made it 120mm taller to fit 240mm AIOs :) Making narrow console cases even slightly wider adds a lot in volume unfortunately, that is why I always try to minimize the width as much as I can.
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
Idk if I have shown the packaging:
Cruceh
This going to be available this week? Want to put this in my TV console but it's only 340mm deep so the p-atx and fractal ridge don't fit.
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
Here it is, make sure to select the proper riser cable:
And if you want a discount I also have few extra prototypes for anyone who is interested, they are basically the same as production cases and come with gen4 risers:
I want to thank you all for your patience, I know it took a long time. This first batch is small but there will be more next year along with white units :)
Sj_b
what's the difference between the prototype and regular? Randomly checked the site and ordered a regular one before I checked here. If its no real difference ill order a prototype instead
Reactions: riba2233
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
Prototypes might have some really small visual marks in general (similar to B-stock cases, but they are pretty rare in this case) and on the panels (you can barely see punch marks around the holes on side panels under some specific angles and lighting) and the gpu holding bracket has hand cut countersinks (which you won't see after you screw it down).
If you want I can just edit your order and refund the difference, just tell me :)
Sj_b
Yes please, I think it would be better for me to get the prototype then. My name for the order should be Samuel Bourg, shipping to the U.S. please let me know if you need any more information, and thank you very much. Words cannot describe how excited I am to build in this! I'll definitely send build pics when it is finished for the gallery on your website.
Cruceh
Bought one. Forgot to add the $5 horizonal stand pads. Does it work with the u-itx? Where do I get those or can it be added to my order?
Reactions: riba2233
