If you have an external brick, yes, definitelySo... would it fit the power brick, mouse and keyboard?![]()
Hello, how are cpu temps for you? I have the same mobo, cpu and cooler. Im hitting 47 Celsius on idle and peaking 96 during overwatch. Im thinking its the cables, theyre stock hdplex 300w. Do you think custom, shorter cables will bring down the temp? I can post pics of the setup.
What speed is your CPU running at, and have you manually set the voltage? I found that fixing the speed, manually setting the voltage and fixing the clock at 4.0 GHz provided a nice balance of silence, performance, and cool temperatures. Those temps at idle seems incredibly high, have you tried reapplying thermal paste?
When I had the HDPlex 300 in there, I didn't see any temps over 70 C when benching and ~63 C when playing Overwatch. Sure, you can post pics. What other hardware is in there, and what's your ambient room temperature?
