Rumor Possibility of AMD on STX form factor
There are so many frieds discussed about AMD solution on STX form factor.
I told Crew ASRock had one AMD FM2+ 5x5 board....
Let me show off one board I found on my boss's table.
We did a very very quick research during CNY.
AMD 2200G box fan is so high that can't be installed into our chassis.
BUT... how about install CPU fan and heatsink separately? HAHAHA...
Only for fun :D
cebali
deskmini A300
Nice. My question is: does the Ryzen boxed cooler with the shroud removed fit in the case?
I checked Japanese prices out of curiosity. They range from $170-$180, but the sites specify that it's the Japanese version with the cooler included. So I guess without the cooler there's a good chance of ~$150 which is a bargain.
Windfall
2,117
1,584
I can get the boards direct from AsRock if anyone would be interested in placing a bulk order @ MOQ 500 ;)
0_o
Ask for an evaluation sample.
Actually, I designed a fanless case. How good it is, I don't know. I'll have to get a board and test it.
Boil
1,253
1,094
This is interesting...
What kind of pricing are you figuring...?
What accessories would this include...?
Would this include the 120W external power brick...?
What about the option of having the DC changed to an internal 4-pin connector, for use with the HDPlex 160W AC-DC unit...?
Might ASRock be open to providing a BIOS that allows X300 activity...?
I am interested...!
Windfall
2,117
1,584
I am interested...!
My Sentiments exactly.
Also make the IO lower profile.
But the MOQ is probably higher for modified boards...
KMPKT
3,382
5,936
I am interested...!
Quote was for 66 USD a board but only includes the SATA cables and I/O shield. Personally I think this board would be amazing with an HDPlex 160W AC-DC inside a single enclosure (ie. effectively brickless). I did enquire about this as well as a better I/O (adding two USB to the rear panel and getting rid of the VGA port) and was told it is possible but I would need to order 50K boards (lol).
As a solution I was thinking that we could bulk order some 160W AC-DC units to go with these that had a barrel connector you could just loop out the back. Case + Board + AC-DC as a barebones anyone?
Windfall
2,117
1,584
That would be AWESOME, but I'd use an HDPlex 80W with mine and underclock the CPU.
Then my HTPC Micro would live!
Boil
1,253
1,094
I am interested...!
66 bucks sounds great; I am down for one, 499 to go...?!?
VGA is an easy removal...
The dual USB 2.0 cable they offer can give more rear USB I/O...?
I guess I could mod the DC in; it shouldn't be that hard, should it...?
Anything towards a X300 BIOS from ASRock...?
I really want to put a 2400G under water & see what some snappy (for SO-DIMMs) DDR4-3200/16 RAM & overclocking can do...
And then start working on a physical prototype for a custom chassis...
Brian_Buckley
47
41
Curious how that compares to the normal price once you buy a 3rd party power brick for it. I'm personally interested in doing a custom case which is why this sounds pretty appealing but I'd probably still do it with a brick.
KMPKT
3,382
5,936
Yep. You can buy them from Japan but it is quite expensive (180 USD + Shipping). Literally just bought one this minute and looking forward to pairing it with a 2400G to see what it can do.
Reactions: NinoPecorino
Boil
1,253
1,094
Showing "Sold Out" right now, but the HDPlex 160W AC-DC is listed at 55 bucks...
That is the internal brick that fit within my chassis dimensional constraints...
What RAM are you getting, & please confirm / test the RAM allocation; manual states 2GB default setting (most of the BIOS I have seen for AM4 ITX defaults @ 256MB & caps at 2GB) & up to 16GB if you have 32GB of system RAM installed...? Would be interesting to see what the 16GB G.Skill kit (2 @ 8GB DDR4-3200/16) can do with 4 to 8GB allocated to the GPU...?
Man, I cannot wait to see some 7nm chiplet APUs in the future...!
Reactions: Jello
KMPKT
3,382
5,936
I have a couple of spares at my place as well as a couple of HDPlex 80W units, so I'll be using one of them. Planning to buy a 16GB HyperX kit @ 3200 MHz.
Reactions: Jello and Boil
