Production No more sandwich. W19. Up to 360AIO and custom loop. Up to full size 3-slot gpu. DDC pump. Ready for uncompromise watercooled in 10.5L console case.
Which kind of case to send to production first?
  • Total voters
  • Poll closed .
Houdini
156
82
thanks for that but it seems the coolgate is not available (anymore?) in my region and I didn't look on aliexpress because I don't trust them to ship a radiator without any damage. I've received a lot of packages where I was lucky that the item itself was not broken 😅
Houdini
156
82
here's a pretty good and thorough article/roundup of radiators: https://www.xtremerigs.net/2015/02/11/radiator-round-2015/
One important takeaway is that some slim rads outperform thicker rads and the general difference between thin/thick is not that big, at least not if you don't go push/pull
The absolute best slim rad is the Hardware Labs Nemesis GTS, but it has a very high flow restriction which could be bad if you use a weaker pump like DC-LT. Would love to test it though...
Reactions: SammyXXM
SammyXXM
230
387
Moldova
anthecase.com
Unfortunately HWLABS is not compatible due 133mm wide.
OK, I'll buy it from OEM and sell it under my own brand. 😁
osin17
I remember about a sff google sheets daily updated with components size, compatibilities and more info. Do you want to get the link ? This is a huge work but not mine 😁
Reactions: SammyXXM
Houdini
156
82
yes please!
but I placed my order for watercooling parts this morning anyway :D
Houdini
156
82
thanks. think i've stumbled over it once but good to now have it linked here forever :D
looks useful though not so much info on radiators and stuff
SammyXXM
230
387
Moldova
anthecase.com
Ok, I designed an 13.4mm thickness adapter for a fitting, any 45mm rad will be available soon. But I'm afraid this thing won't be cheap.
Houdini
156
82
cool thing! I wonder though what the impact on the flow will be because it is so thin. I mean there's water coming with force from a "big" 10mm tube that needs to squeeze into the adaptor :D
SammyXXM
230
387
Moldova
anthecase.com
Quite possible. Need to do tests. I will make a simulation on an acrylic prototype.
Edit
The cross-sectional area of the adapter is slightly larger than the cross-sectional area of a 10 mm tube.
