You have also koolance low profile fittings available: https://koolance.com/fitting-single-black-swiveling-elbow-low-profile
These fittings yet more cool. Now EK-CoolStream PE line avialable! Finally, manufacturers have begun to notice the needs of small form factor users. Now it's time for the awful GPU bracket design.
I meant this ridiculous protrusion
This is part of the frame.Are motherboard standoffs included with the case?
With the new microfittings everything has become much easierDamn, this watercool this case sounds more harder than i expect
I hope it will work 3090 + 240aio.
I thought "CPU cooler clearance" measurements already accounted for that height difference. Typically, CPU IHS is 8mm from the MB PCB surface.Sorry if stupid but I need to ask: what is the distance between the CPU (not the socket, the actual CPU when installed) and the side panel?
Unfortunately, only the 47.9mm height cooler is compatible.
also we need to keep things like this in mindDamn, this watercool this case sounds more harder than i expect
i feel like this used to be worse, and then it got better, and now it's worse again.also we need to keep things like this in mind
so many variables... I need to go and buy Eisbaer LT and then measure all the distances like CPU<->RAM, CPU<->M.2 to see what fittings and stuff even works
it's a real shame that there's apparently no standard for keep-out-zones... imagine buying parts that fit your current board and in 2 years you upgrade and need completely different parts only because someone moved the socket somewhere else...
Or someone changes socket form factor every yearbecause someone moved the socket somewhere else...
I think that if you use inexpensive components from Bykski, you can fit in a much smaller amount. Rumor has it that these parts are quite high quality.this project might be interesting for the W19 too! https://smallformfactor.net/forum/threads/solid-metal-low-profile-ddc-pump-block.16848/
also if someone has the Asus Strix B450i board like I do then here's something interesting too. Especially the images. It seems like it could work in the W19 though it's not totally clear to see how high the fittings on the Eisbaer LT reach up (if it's still below 47.9mm)
Or remove the M.2 heatsink and route like this. This looks like the fitting height should be no issue.
Overall I think Eisbaer (Solo) LT would be awesome because it is the cheapest option. I know, kinda strange wanting to be cheap and at the same time buy boutique casebut I can't see myself spending ~300EUR on a CPU loop lol
Yes, I will buy the fittings definitely from china, Bykski/Barrow/WinKool one of those that saves some money. But the most expensive part is CPU block (65), Pump/Res-Combo (60), 240 rad (50). Then with tube and coolant and fittings, fans it's easily again >200.I think that if you use inexpensive components from Bykski, you can fit in a much smaller amount. Rumor has it that these parts are quite high quality.
Anyway, maybe I actually go with that and bite the (price)bullet. In that case, where would be the best place to mount the pump/res? The one you designed, where would that go and what are the dimensions?
