MovingPixels
We do not have a list for the next run because we're not sure how it's going to work yet.
May just be a few units for internal testing, a small run like this last one, or we may even open the orders to the public.
I wanted to make an account and post here to show my support for this product! I'm definitely interested in the Cerberus and I can't wait for it to come to market. I'm encouraged to know that you are thinking about opening orders to the public. Is there a email list that I can get on in order to keep up to date?
Brasky
Ditto, I'm excited about this build!
Reactions: jeshikat
Diablo
I can't wait for this to be released.
Looks great.
Would I be able to combine a ASUS GTX 1080 strix and a full size modular psu without any problems?
If so, would I be able to have a lil window to show of the flashy rgbs on the gpu? ::)
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
Looks great.
Yes. I posted some pics a couples pages back of a strix 1080 OC with a full cover EK WB and the WB terminals wouldn't allow the side panel to fully seat but the stock cooler should.
MarcParis
Apr 1, 2016
3,681
2,802
When I will receive my cerberus-x, i will also test Msi gtx 1070 gaming X compatibility. I hope twin frozr vi is compatible. I've already bought some low profile pci-e connectors as they are not offseted on 1070..:)
tokyovigilante
Hi, Is there anywhere with updated clearances for GPUs etc? I'm trying to figure out if my GTX 980 Ti (MSI Gaming 6G - 277 x 140 x 40mm) will fit as well as a Nepton 240M cooler either vertical at front or under the GPU. Thanks!
KSliger
Sliger Designs
May 8, 2015
855
3,186
Built up!
i5-6600K @4.7Ghz, MSI Gaming Z170, 32GB DDR4-2400, 2x Samsung 850 250GB, GTX 1070, 500W SFX, Cooler Master Nepton 240M
KSliger
Sliger Designs
May 8, 2015
855
3,186
The power connectors aren't something I can say for sure will clear. Measure from the underside of your card tab to the apex of the PCIE power connector cable top return arch, needs to be under ~48mm.
Nepton 100% fits
tokyovigilante
Nepton 100% fits
Timely build post! That's fantastic, if the 980 doesn't fit it might just be an excuse to go to a standard 1080 Ti. Thanks!
4,784
Looks great.
Welcome to the forum!
If the 134mm height is accurate, then the 1080 Strix should fit.
This is still accurate for GPU clearance:
https://kimeraindustries.com/cerberus/#cerberus-specs
Total number of expansion slots: 5
Maximum PCI device length for all slots: 329mm
Maximum PCI device height for all slots: 130mm at the power plugs; 150mm overall
MarcParis
Apr 1, 2016
3,681
2,802
Built up!
Nice & clean setup..:)
Stupid question from my side : why not putting 140mm on side bracket to exhaust hot air coming from bottom?
