Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
Worth the wait tho...
Josh | NFC
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
You know, I never considered just what an excellent fishing buddy the Cerberus(microATX) could be! Thank you for opening my foolish eyes to a whole new world of possibilities!! :p
Yeah the handle makes a great attachment for a rope. So I've been using it for a boat anchor.
The powdercoat should keep the steel from rusting for at least a little, but for Cerberusanchor 2.0 I think James should consider nickel plated aluminum. Salt water is nuts.
I might not be able to afford a nice boat, but I definitely have the best anchor in Biloxi! And when I am done I can carry it off to work or to a LAN!
4,793
It is not possible to fit 2 let`s say 120mm fans on the side with SFX-L PSU in front? :eek:
There's physically enough space, but the mounting holes on the side bracket are not lined up for it to properly mount the fans.
