!!! time to spend some money !!!![]()
J-HACK Pure X - J-HACK
STOCK STATUS: NEW BATCH EXPECTED SPRING 2021 Just a bit bigger, but a lot more flexible. The J-Hack Pure X is a beefed up Pure. At only 4.3L, this chassis supports a LP dual slot GPU and FLEX ATX PSU. Made from power coated 1.6mm aluminum, it’s light but durable. Designed, made, and assembled...j-hackcompany.com
Expected ship date: 25 SEP 2019.
Included is the 1050 Ti bracket. should be compatible with multiple GPUs since they seem to be based off a similar layout. If you have a single slot card, you should not need a bracket.
If it does not fit your GPU, send me your bracket and I'll provide a 3D bracket free of charge after some quick modeling.
(For those unable to see embeds)
PIC 1 PIC 2
Is the power entry cable (https://j-hackcompany.com/?product=c6-power-entry-to-jst-vhr-3) used in the Pure case also the correct length for the Pure X? I'm supplying my own Meanwell 200w.
Also, is your C5 AC power cord (https://j-hackcompany.com/?product=c5-ac-power-cord) thick and heavy gauge or more suitable for portability?
