News Gigabyte/ASUS/GALAX RTX 4060 Low Profile
Gigabyte is creating an RTX 4060 low-profile card: https://www.tomshardware.com/news/g...-be-the-first-low-profile-ada-lovelace-design
3 fans, single 8-pin, 2 slots.
Pie in the sky, but would love to see an RTX 4060ti (or more crazy RTX 4070) model at some point.
___
16/01/2023 Addendum
ASUS now has a 4060 Low Profile card.
188mm, triple fan.
___
19/04/2024 Addendum
Galax has a card
182mm, triple fan, but the PCIE cable is at the front which will affect clearance without a custom solution.
Will advise to look for something slightly bigger
Cases these will fit into (double check before you buy, not everything is available):
Lenovo P3/P360 ULTRA - 182mm* - Gigabyte (May require modding)/Adapter Needed
ZS A4DC V3 - 182mm* - Gigabyte (May require modding)
ZS D2 (D Config) - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Gemcase C9 - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Lone Industries L5 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod SL3 STL 4.8L Rev.1 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto - 185mm** (Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto+ - 185mm** Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
ZS D2 V2 - 186mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod Case MINI LP edit. - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
J-Hack Pure MK2 - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
Lazer3D HT5 - 194mm - Gigabyte/ASUS/GALAX
Lazer3D Cravo - 195mm - Gigabyte/ASUS/GALAX
CAPTAIN CASE V9 - 208mm - Gigabyte/ASUS/GALAX
REVOCCASES N0RDR1 Nano EVO - 210mm - Gigabyte/ASUS/GALAX
Metalfish 2 Plus - 210mm - Gigabyte/ASUS/GALAX
LZmod A24-V5 V2.0 - 220mm- Gigabyte/ASUS/GALAX
Silverstone Milo ML03 - 223mm - Gigabyte/ASUS/GALAX
Silverstone Milo ML04 - 223mm - Gigabyte/ASUS/GALAX
Metalfish G5 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Bug C1 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
SKTC A10 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Silverstone Milo ML11 - 272mm - Gigabyte/ASUS/GALAX
Diamorif
211
105
I have a 3060 in my system that I bought 2 years ago for around £500, you can now buy a 4060 for £290. I'm not saying that makes the 4060 good value, but it's something to consider.
I'm not disputing your points, they are valid and you're entitled to think that and I do partly agree.
But I also value frames per watt, probably as much, if not more than frames per $. People paid well above the frames per $ value for the A2000, simply because it offered buckets more performance than the next best thing available in low profile, I think that tells you that some people value power efficiency more.
This forum focuses on SFF and for us power budgets are limited, so for allot of people with for example a 200w PSU, you can now get nearly twice the FPS than was previously possible (i.e. 3050 + 65w CPU vs 4060 + 65w CPU). Whether you want to call it a 4050 or a 4060 is besides the point in my eyes if you're getting double the FPS in scenarios such as this one.
stating a more fervent love of low-profile/more efficient cards than most. I do think you're right on the money here. I'm insanely interested in the LP 4060 and relative to the world we just came from where a LP 3050 was $1,000 for the longest time, i do think it is really cool to have something that will fit in smaller chassis without having to muck around with the awkward size and thermals of itx gpus is really interesting. Setting aside the A2000, which is by far the outlier in terms of frames per $, I'm all in for a $300 lp card that can hang with a 1080 ti after buying lp 1650s and 6400s for around $200. I really do think the efficiencies of the last 2 gens have gone ignored (3060 ti is still my favorite release of the past few years). its somewhat ironic to think that a lp version of the 4060 coming out at launch probably would have done a fair bit to improve its reception.
That all said, i am somewhat sad it had to be gigabutt that makes the card over some of the better options, but hopefully, it sells well and others follow suit.
REVOCCASES
REVOCCASES
2,237
3,653
www.revoccases.com
since it's somehow related with the discussion... German website computerbase.de recently did an interesting cost/FPS analysis...
source: https://www.computerbase.de/thema/grafikkarte/rangliste/
anyway, regardless if the price for a RTX 4060 is "justified" or not - for people who need/want a LP GPU it is good news that there's finally something new on the horizon, apart from the 1500$$$ RTX 4000 SFF ADA
Gingerbeer
142
128
Providing this doesn't launch at an obscene premium, I'll likely grab one to replace my A2000. This is the only scenario that makes the 4060 even remotely attractive - I'd still rather have a 3060 LP, though, if it existed.
Reactions: Stifle and Arboreal
scatterforce
405
314
To put this card into perspective, the RTX 4000 SFF is 2% above the 4060 on Techpowerup. That's a $1500 card vs. this soon-to-be ~$300 card.
The 4060 is also 189% of the A2000 with 8GB vs 6GB on the base model. This is the best 4060 in existence that can truly justify its price to performance. Someone at Gigabyte looked at this and realized it's the best way to dump these parts and the 4 memory chips make this very cost-effective to build.
Snerual
211
251
This. I 100% get the hate for the 4060 from a price/perf perspective, but from a perf/watt perspective, the 4060 and 4060Ti are very interesting products.
For a LP card I consider a 128bit Bus with 4 memory chips the sweet spot, so from that perspective it does make sense. However, I think this is only the second time ever that we see a LP card with a TDP above 75W and a power connector. (and previous time was like 10 years ago from some obscure brand) From that perspective this is a truly baffling product. Also this thing will NOT be silent, so again, it's appeal seems limited to crazy hobbyists like us and people that want run CUDA farms on a budget or something.
And that second potential use case is why I am afraid that we will never see this product... maybe it is a custom design for an enterprise customer that wants to cram a ton of these in server racks, to effectively get the same performance as the RTX 4000 for a third the price. I genuinely do not see how any consumer outside of this forum would be interested in this product.
REVOCCASES
REVOCCASES
2,237
3,653
www.revoccases.com
How well do LP cards (or Knife cards as they are referred to in China) do in the Asian Pacific market?
It's also a niche, but much larger then in the west... especially the low cost cards are quite popular...
some small companies in China have even focused completely on LP GPUs and offering such gems like this LP SS RTX 3050 8GB (mobile)
that being said, I'm constantly hitting the refresh button on JD and Taobao to see when this RTX 4060 LP will show up XD
Arboreal
850
851
Jolokia? That's a name I haven't heard in years... Still serving you will I hope.
ondert
348
163
I saw this the other day on Reddit. This might be my next step over A2000, however don't know how long it is and if it fits into Stratos X and if i can power it with HDPlex 250w GaN. Lots of questions on my mind..
Stifle
56
83
Even if the length is prohibitive, I imagine it would be easy to lose one fan to fit into smaller cases.
Definitely going to pick one up for my work pc rebuild, currently in a loque ghost, hoping to reach 1/2 that volume
Snerual
211
251
250W should be fine, since this shouldn't draw more than 115W (especially with a mild undervolt/custom voltage curve in Afterburner) and if you have a 65W CPU.
My plan is to use this for 60fps gaming (at the highest settings and resolution possible, depending on the game), combined with a Ryzen 5500 or 5600 undervolted and locked to 40-45W or so (should be more than enough for 60fps). I am hoping I can achieve this with a total system power draw of 180W or less.
Gingerbeer
142
128
Similar plan for my ZS-A4DC rig - Gunna upgrade it from the 9700T to my 5600G.
I might add a small fan to blow a little air at the 250W GaN though, because it gets pretty warm just pulling 140-150W to run the 9700T & A2000 in there at the moment. There might just be enough room to mount a slim 80mm fan or two in the bottom. Well, "mount" is a strong word... more likely a little 3M gell tape :p
K888D
Lazer3D
Feb 23, 2016
1,483
2,970
www.lazer3d.com
Overlaying the side shots available with other cards we know the length of, it looks like the card is 180mm long and the PCB with the power connector on the end is 160mm:
I wrote an article with a bit more detail here:
Stifle
56
83
I roughly scaled the images of this card with pixels compared to known lengths and it comes out to around 185mm by ratio. A little long for my planned/ purchased case but the shroud looks to be extra long and could be trimmed
Reactions: ondert
Snerual
211
251
Even if you trim the shroud, the 8pin connector sticks out the back, so unless you get some special low profile connectors, the total length will still be 180-185mm. My J-Hack Mk2 is 190mm long so I am hopeful 🤞
robbee
n3rdware
887
1,403
I did the exact same thing with the RTX A2000 and came to some higher numbers:
