is there ever going to be a cpu for the z490 chipset/socket that supports pcie40I'm an idiot, I was talking about the upcoming Z490 ITX boards. But eagerly awaiting to see the B550 layouts.
End of summer. August-September.I made an account specifically because of this case.
It's looking amazing. Can't wait on all to see all the completed builds.
Too bad I'm late for the first pre-orders.
What are the estimates for the backorder? Do you have an expected fulfillment day?
Edit: Received my black tubing and GPU block. Only waiting on the GPU, fans, pump, Quadro and temp sensor.
If the rads are 30mm or less in thickness, and you want to use 25mm thick fans, then yes.Just to clarify - the large (not x-large) double top/bottoms should work fine to add 2 280mm rads?
Propably just going to use the fill port in the front of the distro, just turn the case on its face. Alltough, would need another port somewhere to let air in i ques... so might actually have to put drainport somewhere... maybe one of the bottom rad connections...Where are you guys going to put the drain port?
also, my case will have uncovered front/back on expand, so a drain valve can just poke out from the front or the back with a T junktion right at the rad port. i ques rad ports go to the front of the case? on both top and bottom?Same thing as I was planning, or one of the lower distro ports as it flows towards the bottom rad. Any way its gonna be tricky.
Tbh idk yet how I'm gonna route my ways atm. Need to have the case in hand before I decide that. I do enjoy a parallel line under the rad but it remains to be seen. Guess same goes with the port at this point. I bought the things to fit a drain valve but... It remains to be seen. Maybe @diceboii13 can shed some light as to where we can cram that. At this point I have a job figuring out some other things.also, my case will have uncovered front/back on expand, so a drain valve can just poke out from the front or the back with a T junktion right at the rad port. i ques rad ports go to the front of the case? on both top and bottom?
I personally like the front transparency in play with the TG on the sidesSince the distro and front plate will be full clear acrylic, i need to sort if I want lighting showing through it, might need to figure out a difusion layer or if I want to blank some bits of it so it does not look straight inside the "guts" of my rig.
I know, I literally cant sleep ? BUT, Tomorrow is the day of painting the first ones (finally). The Lagune color is not arrived to the factory, so tomorrow there will be just some Oxidian, and Glacial cases. Shortly after that,maybe in the end of this week it will arrive. Some leaked photos from the "Dice factory":*impatience intensifies* ??
Its kinda hard, but if you put some effort in it, it can be done. The worst part is waiting when I cant do nothing ?Well damn. I've been containing my excitement for a bit, but now it's much harder to do so. I am honestly surprised how smooth things seem to be going considering COVID19 and how hard it can be in general to make something this complex.
