Added some extra feature for the distro: A place for an RGB strip. It turned out great! (Its a DDC one)
Where does the strip go in the plate? How long does it need to be? What did you use in these pics?
It goes in the rear side, theres no disassemble required, some double sided tape just do the work. The hole is around 9,5cm long. I used an old RBG strip, that I cutted to length.
Its 12mm deep and 6mm wide so it should be fine.The RGB bit is awesome, couldn't ask for more. However what is the depth? Usually most RGB strips are 5mm+ wide. Also I'm thinking I'll go for a really dense DRGB strip since my fans are non RGN. Noctua powa!
Also THAT'S A FAKIN CUTE DOGGO U GOT THERE! ?
Cool, I see it now! I'll have to find a ~10cm ARGB strip to go thereIt goes in the rear side, theres no disassemble required, some double sided tape just do the work. The hole is around 9,5cm long. I used an old RBG strip, that I cutted to length.
She is a 4 year old crazy husky who doesnt like COVID-19 ?
You can get a bigger one and just cut it in the right place, its really simple.Cool, I see it now! I'll have to find a ~10cm ARGB strip to go there
Can you cut 5v ARGB strips, or only 12v strips?You can get a bigger one and just cut it in the right place, its really simple.
Received my Nf A14 chromax and D5 pump today ??. Went with alternating black and white anti vibration pads. Looks really nice.
It will fit, but I dont know how to cut these thing to the length. Maybe you can just sqeeze in the rest of it in the bottom of the case.How wide is the RGB strip hole? Wondering if Phanteks Neon would fit in there sideways (5.1mm wide it seems):
Phanteks Innovative Computer Hardware Design
www.phanteks.com
CPU: Ryzen 7 3700XWhat's you RIG
By now the date is approaching, soon this wonderfull case will be in your hands,
I would therefore keep to know which buildings will gloriously go "underwater",
This is mine:
CPU: i9 9900K
MBO: AsRock Z390 Phantom ITX
RAM: Corsair VENGEANCE LPX DDR4-3200 (2x16GB)
GPU: XFX RADEON VII
PSU: Corsair SF750
(COPY>PASTE AND CHANGE ELEMENTS)
What's you RIG
This is mine:
CPU: i9 9900K
GPU: XFX RADEON VII
PSU: Corsair SF750
What's you RIG
What's you RIG
