Small gap: 27mm Large gap: 57mm Extra Large gap: 73mm@dice what are the sizes of the gaps when expanded?
Sure, I will notice everybody when delivery gonna happen@diceboii13 is it possible to change the address of the delivery?
With this coronavirus problem, the delivery address was my work address... but now that everyone is working from home, I would like to get some notice before delivery happen.
Unfortunatelly yes But there will be a second batch soon after that!@diceboii13 did I miss possibility to preorder?
Yeah is the Nexxxos is a really tight fit, I worry about the HWLabs Nemesis GTS fitting... The Nexxxos says its 144mm wide but the GTS is 153.@diceboii13 Can you take a pic of how much space is on the side of that radiator... just for reference, there are chunky boys out there...
Alright thanks for checking, you probably gave a few people here a heart attack with the "perfect" fit commentThere is 157mm space for radiators in wide. So it will be a tight fit ?
EDIT: I measured, 156mm wide rads will fit.
Now it hasnt got a loop inside, so it was pretty easy. I filled once almost full, then roatate a bit to get rid of the air in the pump, then filled up completely. With components, it will be a bit more but for me it takes like a minute. If tomorrow I got my package, I can show you a full loop, and how it works in this weekend. I will make you guys entertained when the parts are made. ?How long did it take to fill using the distro? Also, any tips on bleeding?
Awesome, look forward to seeing the full loop! By bleeding I meant emptying the system of water. I see people sometimes using those dedicated drain ports with a valve but not sure there's really space for something like that... For example:Now it hasnt got a loop inside, so it was pretty easy. I filled once almost full, then roatate a bit to get rid of the air in the pump, then filled up completely. With components, it will be a bit more but for me it takes like a minute. If tomorrow I got my package, I can show you a full loop, and how it works in this weekend. I will make you guys entertained when the parts are made. ?
I didnt saw any bleeding since monday so its safe. Some paper towel is required to fill it up completely, because the stop fitting will push some fluid out when you screw it in. After around half an hour the remain micro bubbles will come out and stays at behind the stop fitting, so you can remove them.
Oh sorry, Ill try as soon as possible, bit I think if you turn the system upside down, the fillport can be a drainport aswell.Awesome, look forward to seeing the full loop! By bleeding I meant emptying the system of water. I see people sometimes using those dedicated drain ports with a valve but not sure there's really space for something like that... For example:
Useful Tips Part 1 - Drain Valve - ekwb.com
Oftentimes not having a drain port, or placing it in a bad spot can make your liquid cooling experience complicated. At one point you will want to do your yearly coolant swap, or just want a new coolant color, or you will want to change liquid cooling components. In any of these cases you will...www.ekwb.com
Yes, we didnt start the production line yet in the metal part.@diceboii13 is it too late to change the colour of the case? Just asking for a friend...
That white look awesome!
Sorry I meant we can change it, that turned out wrong ?@diceboii13 is it too late to change the colour of the case? Just asking for a friend...
