Just tried a light sand blast on a distributor to remove the machine marks. Once coolant is added this goes clear.
Can we see this with liquid inside? I actually really like the matte look.Just tried a light sand blast on a distributor to remove the machine marks. Once coolant is added this goes clear.
Yes it turn full transparent when you put liquid inside.Can we see this with liquid inside? I actually really like the matte look.
As I remember 45, so its around what I expected.How many preorders did you get in the end?
I hope you guys do the special numbered plaque/designation on each of the first 45 to 50 unitsAs I remember 45, so its around what I expected.
There will be numbers in the distroI hope you guys do the special numbered plaque/designation on each of the first 45 to 50 units![]()
If we later change expands and need to get new "covers" - will that require changing the whole plate, and thus losing our plaque ?There will be numbers in the distro![]()
No! The number will be in the rear plate. For changing the expands, you just need a new frontIf we later change expands and need to get new "covers" - will that require changing the whole plate, and thus losing our plaque ?
Aw you guys thought of everythingNo! The number will be in the rear plate. For changing the expands, you just need a new front![]()
It will be included. Only the 2 stopfittings gonna miss because I cant find any OEM who make a good one.In terms of GPU Riser, what length you think its needed?
Bykski B-PD5 G1/4 Frozen Dragon Blank Plug - White ??It will be included. Only the 2 stopfittings gonna miss because I cant find any OEM who make a good one.
Would prefer something without the dragon logoBykski B-PD5 G1/4 Frozen Dragon Blank Plug - White ??
Colour is what I'm going with to match but them look good. Also quality is on par with Bits power afaik.
Kinda, I found an OEM but the quality isnt the best. But there is a logo in the powerbuttonWould prefer something without the dragon logoI bet Dice wants his logo on the fitting is why he's looking for an OEM specifically.
