Did a bit more testing with fans turned off completely during a cinebench run. And it does become very apparent that the average CPU temp scales relatively linearly as the water temperatures rise, with a relatively stable delta of around 30-35C between water temp and CPU die temp. If 40 is considered within normal parameters, then it sounds like I'm well within the expected zone. I'll try to tweak the fan curves a bit to try and keep under that 45C ceiling where components will start to be in the danger of throttling. The flow rate doesn't seem to make a noticeable difference so I'm keeping the pump speed constant for now.
EDIT: Here it is "stabilized" aiming for 40C max while running Cinebench.
Looks like I will need to boost those fans speeds higher once I connect the GPU to the same loop... which is kind of a bummer because with these settings it's just on the threshold of being inaudible.![]()
Was curious as to what temperatures people are getting with their builds (and how they were running the various components).
I am running a 3900x on the Asrock X570 Mini ITX with an EVGA RTX 2080 Super (using the Hydro Copper GPU block).
I was running the fans (Noctua NF A12) @1000 rpm and pump (Alphacool Eispumpe VPP755) @3500rpm and then decided to run the Time Spy stress test and ended up getting 78C as max temperature (idle temp for GPU was 27C). Having never done this before, I assumed something was wrong with my installation of the GPU block so I decided to drain the loop and re-seat the card. In hindsight, I was clearly expecting too much - I wanted the system to be quiet and cool.
Anyway ended up re-running the test and same temps! So I decided to run the fans and pump at full speed and then end up with a GPU temp of 66C. At this stage I am assuming my installation of the various blocks is correct and I need to tweak the fan and pump speed to find the sweet spot of silence and performance. Thoughts folks?
