DAN A4-SFX v4.1
wolf30
You're an hero.
thx bro.
No problem, hope it works for you
Its the same size and all, but you have to mod it tho. I dont think dan would sell those for some users.
Im quite curious about this actually as this is the only advantage of v3 over v2, but I am curious what is the limitation of using HDPlex instad of 92mm AIO, true with HDplex you can use 120mm radiator, but do I have to sacrifice GPU? can I still use full length 1070, 1080 or 1080 ti? or evne the 2080? is there any other thing that I need to keep in mind of using HDPlex
Nanook
805
793
You can use a reference length GPU, with the HDPlex sitting behind the front wall.
External bricks are the limiting factor for now. The most common laptop bricks (19-24v) only goes up to 330w. The Eurocom goes to 700+ watts, but is very expensive. You can find some cheaper industrial power supplies going up to 1200w.
DarkCanuck
60
28
If you check out this forum:
https://smallformfactor.net/forum/threads/hdplex-400w-ac-dc-internal-adapter.7069/
Or:
https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
HDPLEX will have an internal 400w AC-DC adapter option, to go with the 400w Plex.
A number of the forum members have also been taking about creating an external enclosure, to transform the AC-DC adapter into a brick.
Nanook
805
793
Or:
Thanks for the reminder on the 400w AC adapter. I am looking forward to having a much smaller brick.
Reactions: DarkCanuck
Tazpr
552
426
Thought I'd share some pics of my completed DAN A4 V2 build.
Just looking to get some windowed panels now, but absolutely adore this build, couldn't be happier!
dondan
DAN Cases
1,966
8,288
Here is the RTX 2080 & RTX 2080 Ti compatibility list:
RTX 2080 Ti Cards:
NVIDIA GeForce RTX 2080 Ti Founders Edition = compatible
ASUS Dual GeForce RTX 2080 Ti Advanced = incompatible (3 Slot)
ASUS Dual GeForce RTX 2080 Ti OC = incompatible (2.5 Slot)
ASUS Turbo GeForce RTX 2080 Ti = compatible
EVGA GeForce RTX 2080 Ti XC Gaming = compatible
EVGA GeForce RTX 2080 Ti XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix GS = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix = incompatible (3 Slot)
Gigabyte GeForce RTX 2080 Ti Gaming OC 11G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Ti Windforce OC 11G = compatible
INNO3D GeForce RTX 2080 Ti Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Ti X2 OC = compatible
KFA² GeForce RTX 2080 Ti OC = compatible
MSI GeForce RTX 2080 Ti Duke 11G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Ti Gaming X Trio = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro OC = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro = incompatible (3 Slot)
PNY GeForce RTX 2080 Ti Blower Design = compatible
PNY GeForce RTX 2080 Ti XLR8 Gaming Overclocked = compatible
Zotac Gaming GeForce RTX 2080 Ti AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Ti Triple Fan = incompatible (3 Slot)
RTX 2080 Cards:
ASUS Dual GeForce RTX 2080 OC = incompatible (3 Slot)
ASUS ROG Strix GeForce RTX 2080 OC = incompatible (2 Slot)
EVGA GeForce RTX 2080 XC Gaming = compatible
EVGA GeForce RTX 2080 XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Phoenix GS = compatible
Gainward GeForce RTX 2080 Phoenix = compatible
Gigabyte GeForce RTX 2080 Gaming OC 8G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Windforce OC 8G = compatible
INNO3D GeForce RTX 2080 Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Jet = compatible
INNO3D GeForce RTX 2080 X2 OC = compatible
KFA² GeForce RTX 2080 OC = compatible
MSI GeForce RTX 2080 Duke 8G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Gaming X Trio = incompatible (3 Slot)
MSI GeForce RTX 2080 Sea Hawk X = unknow
MSI GeForce RTX 2080 Ventus 8G OC = unknow
Palit GeForce RTX 2080 GamingPro OC = compatible
Palit GeForce RTX 2080 GamingPro = compatible
PNY GeForce RTX 2080 Blower Design = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Triple Fan = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Twin Fan = compatible
Zotac Gaming GeForce RTX 2080 AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Blower = compatible
