Oh nice to know that undervolt is available on the beta.
On the topic of cooling, wonder if there's a reason folks aren't doing more top mounted AIO's? Seems like it should be popular and heck even the default!.
I know it's not officially supported, but dont see why it cant be done if you reposition the PSU. Agree with you that the bottom AIO seems a bit sketch (as per Gamers Nexus vid).
This guy ? , so talented. Something like this possible for AIO crowd ? Notice the PSU shifted down to accommodate.
I thought hardware unboxed said the opposite, but maybe they were mistaken.LTT said they don't run even a watt hotter than the previous generation at stock.
Well one aspect is not covered with all those benchmark : loading times..Yeah even at 1440p going from a 3600 to the 5600x doesn’t make a lot of sense for gaming. The 1080p gap is impressive so people looking at new builds or coming off a Ryzen 1000 or even 2000 cpu it’s looking good.
The entire board is shifted down 1 slot (motherboard stand-offs would have been moved as well), else there's no way to fit the radiator at the top. So I think that explains why you don't see this more often.
I would love to see a Cerberus X v2 with a detachable bottom (to flip the case easily) and a more "airflow friendly" grill, like the new ITX models,All those optimizations (offset by 1 slot, different PSU mounting points, USB ports, back radiator position like O11, etc)...I guess Cerberus/X needs v2.0..![]()
Flippping top/bottom are coming to Cerberus/X :Is this the proper thread to share opinions for new variants of Sliger creations? Would a new thread be ideal? I was just thinking I would like a Cerberus/X 2.0 with a few options.
1.) Reverseable / top mount GPU. (looks like the S610 and S620 do that)
2.) A little more vertical height extending away from the motherboard for a pair of top 120mm (or even 140mm) non-slim fans (for liquid folks that could help with top radiators).
3.) USB-C and 3.5mm top jacks in addition to the current USB jacks.
4.) Different PSU mounting like the S610.
5.) All the above options while maintaining a handle.
6.) A non-perforated top lid that also accepts a handle.
Would someone be kind enough to provide me of the inside measurement between the front chassis panel and the front cover for the Cerberus (non-X, but I assume they share the same dimensions in that regard) ?
I have my case on backorder for at least a few more weeks and just planning stuff in advance, wondering if I could stuff a passthrough 2.5mm + 20mm Koolance low profile 90 (so 22-23 mm total) inside the front gap?
Thanks!
Inspired me to head over there and skim the thread. Found this gem. Convinced to wait on one of those for my next build.
