Power cord faces up and does not stick out more than 15mm from the PSU.
That's what I needed. Thank you.
Had a bad experience with an AIO in the past, but am thinking about trying once more.
In the (non-x) Cerberus, are we advising push or pull with a 240mm rad on the bottom? I know push-pull or the inverse would be ideal, but my 1080ti prevents that.
If that's a bust, probably switch to a C14s or Dark Rock TF. Have the latter in my M1 and have had no issues with it.
For the C14s, I understand it's best set up to exhaust out of the side of the case, correct? I have a 92mm on the back, 120mm on top and a 120mm in front as well.
Here too. I prefer, by far, C14S with exhaust fans on it. It so efficient to remove hot air coming from GPU..I've had excellent C14S results with it as exhaust and two 140mm fans on the bottom as exhaust, using the window side panel to create a negative pressure case. The 92mm rear fan is set to intake, and that and the perforated top panel supply fresh air. But I also have a Morpheus II on the GPU with its fans set to exhaust toward the bottom as well. This setup basically puts both the CPU and GPU at 70-75 degrees under load, and Noctua fans keep it pretty quiet/at low RPMs.
I had a H100i PRO before and changed it for the NH-C14S (one 92mm rear and two 120mm slims in top, all exhaust), and the results are great. Cooler and quieter GPU, cooler RAM and M.2, and very similar CPU temps.Had a bad experience with an AIO in the past, but am thinking about trying once more.
Ryzen 7 3800X, overclock [email protected]What cpu are you guys using? I have a 2700 overclocked to 4ghz at 1.3v and I’m cooling it with the Kraken x52. In some stress testing I never saw it go above 65c and it was still whisper silent. I can’t imagine the c14s would be better than that. I have the window panel too, so I don’t think my results would be the same.
For my point of view, window panel and C14S are incompatible as window panel will stop all airflow.What do you think is the best orientation for the c14s with a window panel? I take it I’m better off with the Kraken x52 with the window panel?
I am looking for recommendations on case fan type and placement?
The build consists of:
Cerberus X on the way Grey w solid metal sides.
Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
AMD Ryzen 7 2700X 3.7 GHz 8-Core Processor
Scythe FUMA Rev.B 79 CFM CPU Cooler
G.Skill Ripjaws V 64 GB (2 x 16 GB) DDR4-3600 Memory
Toshiba X300 5 TB 3.5" 7200RPM Drive
Western Digital SN750 1 TB NVME
PNY GeForce RTX 2070 8 GB Blower Video Card
EVGA SuperNOVA GM 650W SFX PSU (this does not have additional 4-pin (12v) ATX power connector, not sure if it will be an issue?)
I will eventually replace the the 2700x w a 3950X in about a year or so once prices have dropped a bit.
I picked the EVGA SuperNOVA GM 650W SFX PSU because it seems that SFX PSU's are pricey right now and it was the lowest price for a min of 650w.
It will be used as a workstation for 3D modeling and rendering w dual monitors. Little to no overclock, looking for stability and low noise.
Based upon this build by rcradiator, it seems that 2x 120mm fan intake on the bottom and 92mm exhaust fan in the back will be suitable? Would prefer a Negative pressure case (dust?) but will have Demci-Filter dust filters in-place)
Seems the corsair ML120's will work but wondering if a less expensive model of fan can provide similar cooling a noise levels (DEEPCOOL RF120M..)?
Also debating eventually replacing the blower with a Morpheus II wfans if they can help w heat and noise levels?
Here is my Pcpicker part list:
https://pcpartpicker.com/user/zugok/saved/#view=jfnZf7
This is a replacement build for my ~8 yr old Dell 990 Mt i7. It also may replace ( or simply be used in conjunction with..) my 2010 Mac Pro w Dual x5690's.
Will post photos when I have all the parts I need.
Cheers
JH
No issue..Hey Marc, I appreciate the welcome, and thanks for the feedback.
I have no experience w AIO cooling, I have asked Sliger to add the vented left side panel to add some flexibility. Never the less will stay w the Scythe Fuma for now w the 2700x. Also switched the Corsair SF750 so maybe that will mitigate heat a bit more too.
Based upon your advice and some reading I will have 2-3x 120mm fans as intake, 1x120mm 1x92mm exhaust top and back respectively. (leaning towards Corsair Ml120 or Noctua NF-F12 2000)
I remain open to fan suggestions.
I will hold-off on replacing the GPU blower for now, as my budget is blown into pieces.
Cheers
JH
Does that mean you don’t have space on side of your case?I wanted to find a ATX case that is 7" or less in width, as I have found only the Thermaltake Core G3 and the Cerberus X are.
This system is a replacement for my Dell Optiplex 990 i7MT and that case is also just under 7" wide. I was tempted to buy an old 990 case and use it but it seemed to be risky and time consuming.
welp. no more mATX for HEDT.
damn this hurts ,_,
