loader963
665
571
Va
The first time, I put it between the GPU and the bottom rad at the back. However, I changed it to between the two radiators in bottom front when I changed up the loop as I thought it looked cleaner. No pics of the changed one, but it turned out nicer imo.
Reactions: TheHig
Nanook
805
793
Did you try to clear the bios with the button in the rear io panel? Sometimes with my z370-i I had to clear it when I got too aggressive trying to OC and had the same symptoms you are describing.
Yes, the only way to get the motherboard to boot is to unplug the cmos battery. This was a huge pain in the ass with the massive VRM heatsink-i/o shield combo on the Asus Z390i.
Reactions: loader963
VegetableStu
1,949
2,619
did you remove the PCIe mounting cover before installing? o_o just to check
VegetableStu
1,949
2,619
it's alright, LOL. trivial mistakes are nothing
EDIT: for reference, the reason why there isn't a cover for most other cases is because the mounting tabs are inside the case rather than outside, so that's not a thing in those cases
sjug
Once our handle delay is over and the coupon for OptimumTech expires we will be getting on NewEgg. I need to check back in with Joshua / Dan / Wahaha about SFFLAB - they have a lot planned and a bunch of projects, will see where this falls.
It's been another few weeks since the coupon expired, what's happening with NewEgg?
KSliger
855
3,186
Same as delays with the other cases I was developing - we had large existing customers buy out all our production capacity well past end of year. We're running 24/7 right now, I am at the limit of what we can do until new equipment is in budget.
Also, coupon code!!
BLACKFRIDAY
Is active now until 11/30 for 15% off Cerberus and Cerberus X.
15% off also applies to all part orders such as panels / brackets / accessories for anyone that is changing up their build, or replacing parts.
