You can really mount them wherever it fits. The infinite vents vre really flexible.
Thanks again. I believe I read at the beginning of the thread that the case has two different frames depending on the PSU you want to use. Is that still the case? Or can you order all the adapters and just move the PSU from front to back as you need? My preference would be to front mount, but if I need to pivot and rear mount the PSU, I don't want to be SOL.
Are these circles removable plugs? If so, how large is this opening when removed?
Yes, and 2.5cm.
Thank you! About how large is that panel altogether? I know that it supports 92mm fans, so I'm guessing between 92-100mm?
Sorry for the late reply.
The pump/res combo initially required placing the parts in a certain order, but now I'm familiar with it and have learned that I can just put the pump in first and let it rest/stand on top of the GPU. Then, I simply close the side-bracket and attach the pump to it using the screws/washers. I haven't encountered any performance or temperature issues. The GPU runs very cool and the CPU runs okay at stock. The CPU in general runs pretty hot though and that's why I decided to water cool in the first place. I ended up giving up on running all cores at 4.2GHz+ because of the voltage requirement and decided to leave it at stock.
Any thoughts about https://pcpartpicker.com/list/XyJBhy?
I’ve got a Cerberus grey slate on the way (just ordered)! Basically I’m replacing my 2500k system which has served me well enough for editing and gaming, am looking to downsize and have a thunderbolt port available.
I wasn't planning on any crazy OC, but if I were which cooler would you choose? Which dust filters? I figured the 450 would cut it because it's that list plus another SSD and a few random componentsLooks good! I'd assume with the Noctua cooler there isn't going to be any intense overclocking. The SF450 should be okay.
Get some dust filters for the front fans and you're all set.
My only advice will be to go for sfx-l psu...by far quieter than SFX on load..Any thoughts about https://pcpartpicker.com/list/XyJBhy?
Thanks a lot!
Actually, I am trying to have the pump connected to the radiator/fans, to have the possibility to open the hinge and have shorter tubes.
I will use a DDC BTW and the fan pushing air from the front.
One question How is the Hardware labs 240 compared to the 280? I will use it with the new sterrox fan, and if the cooling performances of both are for few degrees similar, I prefer to go with the 240 and stuck all the cables behind it!
Your custom loop is helping a lot to study mine! especially because I will have 3 GPU, an SSD on the hinge, so space it will be so tight!
What is the lead time if I order this case?
Well the difference between 240 and 280 is only 40mm of rad space so the differences in performance are likely minimal. I wanted to max out performance though so that's why I went with a 280. I'm sure using another 240mm rad will be just as fine.
Thanks a lot!!In stock on both sizes, all options, and all colors. We typically ship same day if you order before 2pm PST, or next business day unless there's a large quantity of orders - then it's processed by oldest orders first.
I would go 240mm, 280mm fits but it is so tight.
