I don't think that's ever been said sincerely beforeYAY WINDOWS UPDATE![]()
My case is not currently fit for public consumption, sadly (got it up and running in ~70% of it's final configuration while I wait for the arrival of a shorter gpu waterblock for my 1080 ftw)Where are all finished build pics?)) Thread gone silent.
Hey @KSliger, got any teases for the window panel while you are at it?
Can't show a picture yet, but here's how it will look on empty shell
Is there the half-window with vents? o_o
I second this question - I'd really like a windowed side panel, but not if I have to sacrifice performance for it...
Thoughts on this window and bracket?
@KSliger
It would be great if you could offer a version that has the USB ports on the front panel.
If you don't have plans to offer one, will you allow users to order custom modifications? A quick and easy modification in this case could be:
1. Don't cut the USB ports on the top panel.
2. Make a rectangular cut-out to the front of the case frame. This would allow the usb cables to pass through.
3. Make the usual USB cuts outs on the front panel. (4 usb cut outs for me please)
Naturally, this change would be a hack and would prevent the front panel from being removed,
but it would be good enough for my needs. All of these changes would in no way alter the dimensions
of the case, so assembling it would be the same.
Thanks,
Stephen
Had to give up on fastener hardware and go with 3M VHB, original James style window:
But that got me thinking since I can't see cable clutter up top the cable clutter at bottom front is gonna drive me nuts...
So cover it with SSDs!
Plenty of room for power cables without the visible mess.
I asked this version long time ago, and the answer that it was too expensive to build..What about a fully ventilated top to bottom side panel? Can it be an option?
