Johnny0971
24
37
Hello Johnny and congrats on the case!
With 25mm fans up front, there is approximately 312mm worth of space for a GPU (personal measurement from back of case to direct contact with the fan shroud). Without case fans, 330mm is the max length of a GPU this case can support (according to official Sliger specs, likely leaving ~7mm to account for angled installation requirement at that point).
I think that if you slot in the gpu first and then slide the fans into position at the front of the case- it should work. If you run into any issues, there's nothing a little sandpaper can't do to lower the height of a fan or reduce the plastic GPU shroud itself.
If you skip the top-most intake fan, you could mount the 2.5"/3.5" drives comfortably at the cost of airflow behind the PSU over the VRMs.
With the inclusion of the swinging arm bracket, you cound mount a single 2.5"/3.5"drive to that as well -the Enermax cables are pretty forgiving.
However, if you can swing it -my best recommendation would be to stick to M.2s, or make use of an external Samsung T5 and keep the ventilation at optimal levels.
Thanks for your very informative reply : ) That was quick.
Sounds promising that there is 312mm space for the GPU, that means that it should fit in theory. I would like to have at least one 120/140mm Noctua fan in the front as intake, and a 3,5 4TB drive in a HDD bracket above the fan, if it doesn't conflict with the GPU. If it does conflict, I can simply install 2 fans instead for better airflow.
Correct me if I'm wrong ,but I can't use the swinging arm bracket togheter with a rear mounted ATX power supply?
I can buy 3 M.2s but that would still not leave me with alot of storage space. Would the space next to the motherboard be available to mount 2,5' SSDs, the holes are there so it should work?
Choices choices : P
Edit; I did notice a few quality flaws on the case, nothing major though, only thing that bothers me is that the paint seems to be missing / chipped away at some extremely small parts on my top panel edges, is this normal or is the paint supposed to cover every mm?
Anthony
79
36
I just wanted to chime in and say that I could NOT get my vertical mounting solution (requires dremel modding) to fit with a 240MM rad at the bottom. Even if I somehow could, the FTW3's increased height would have likely collided with the ATX PSU in the Cerberus-X (pic).
That was originally my plan but the height of the rad+fans proved too tall, so unfortunately I had to gave it away to a friend's relocation project instead.
Now, had I gone with a standard size GPU like the 1080ti Black with a 240/280MM rad mounted to the front the case, I think that a vertical GPU mounting solution would have worked flawlessly.
There's also an ArticStorm Mini that's much smaller. It will likely fit with a vertical mount. The main issue is that I've only found it at two retailers, in Australia and Japan respectively.
MarcParis
Apr 1, 2016
3,836
2,998
lol, guys i don't understand...why are you considering shorter gpu (like artic storm) that is prone to higher coil whine than longer ones...:)
why not simply consider a MSI trio or asus poseidon (not sure this later one is fitting cerberus-x)?
minhbao92
28
21
I wonder why ordering a Cerberus X with ATX Plate + an extra SFX Internal Kit ($285) is more expensive than a Cerberus X with SFX internal + an extra ATX PSU Plate ($267)?
minhbao92
28
21
I order mine with internal ATX, and now I want an extra SFX Internal as well. But it is more expensive than getting one with internal SFX and ordering an extra ATX. I am not happy with that :D
TheHig
951
1,171
Shoot @KSliger an email and or PM here and they should be able to help you get sorted. Can’t hurt to ask!
Also has my case shipped!? —shameless piling on here. Lol.
Edit: hopefully you guys are buried in orders and this chassis is the huge success it deserves to be.
TheHig
951
1,171
I'm so torn on standard or Cerberus x :(
X was my choice due to it being only slightly taller and allows for the most component support. I plan on making this the last case I own that has ATX support. It’s the smallest out there that still allows one to go “big.”
My 2 cents
W1NN1NG
616
532
I feel like I'll go x. As much as I love the overall size of the standard. There just isn't matx boards there. I'm sure there will be more once h370 etc comes but right now I think I'm gonna go with the x. Even though I feel like there's going to be too much dead spaces for me that way. IDK.
Chann3l
78
68
There are a few good z370 matx boards. I went with the non x and picked up the msi z370m gaming pro ac board for my upcoming build. Should provide a stable platform for overclocking and is crammed with features.
W1NN1NG
616
532
Yeah I'm not a fan of the msi one for this go around sadly :( nothing to do with features as it does pack plenty. I just don't like the aesthetic. The strix looks nice but I don't like the pcie placement for sli :/ in case I end up going that route
Chann3l
78
68
Ah ok, I love the all black aesthetic but if you're not a fan of that then the asrock pro4 is probably out too lol. They really need more matx boards though. The EVGA micro is not good either because it's missing 2 dimms.
W1NN1NG
616
532
I actually don't mind the ASRock. I think I'll make the decision come march. That's when I plan to do my build or at least when I plan to start it
Reactions: Chann3l
FoskcoRS5
Designated LMG
Jan 31, 2017
363
623
Personally I think the Z370G is the best option. It supports SLI founder edition cards in the two PCIE slots. The ASRock has the lower slot but then the card interferes with whatever is on the bottom of the chassis. Old pic for reference.
I just noticed the VGA and DVI connectors built onto that ASRock and I cried inside.
W1NN1NG
616
532
Yeah, I kinda want the og cause I kinda wanna mod the panels to make it look like Nova did. With button on front panel. It'll take some body filler but I think I can handle it
