Oh yeah the ASRock X570i Phantom Gaming TB3, thunderbolt 3 is a great feature for me. No idea if that one fits so maybe someone can tell me.
@VELKASE Michael Are you planning a new iteration of Velka 3 any time soon? Just wondering if support for modular Flex ATX PSUs is in your mind? I know you mentioned that you lose 1-2 cables max compared to non-modular so in that sense, there's little point going for modular, but it's more the ability to switch to flexible cables of the exact length for optimal cable management, which is my preference.
Calling that PSU Modular is I guess technically correct, but not useful. Best I can tell it has two cable bundles: 24-pin/4+4, and SATA/Molex/FDD. It does probably make custom cables easier since you don't have to open the housing, you just have to figure out how to wire it to that 10-pin. I think the standard Molex to 6+2 uses two molex 4-pins. So you should be able to look at how the 2 Molex connectors are wired on the FSP compared to the Molex to PCIe adapters, and get it wired properly.@oldmonk I was looking into the FSP FlexGuru 300W a few months ago and Michael had said this should fit in Velka 3 since it's a standard Flex ATX sizing. The other modular ones like GEEEK are modified PSU's adding the modular board to the end of what I presume is a standard sized Flex ATX brick hence those not fitting.
The biggest problem with the FSP is there is no native PCIE power harness. What I've seen other people do is use Molex to PCIE adapters. Not knowing too much about power delivery and the effects of using such an adapter, this would be a questionable item for me. Also, another issue which I have is that the FSP, to me, seems "semi-modular". You don't have individual harnesses per component (i.e. 24-pin, 8-pin EPS, SATA, etc.); those harnesses would share the same VDC outputs from the board. This could be good and bad I guess. If I did try this PSU, I would be doing my own custom cabling, so the "semi-modular" part wouldn't bother me so much. And I did try to do a pinout of the FlexGuru (though I don't have one), so you can check my post here and try to make sense of what would need to be done to get it going in a Velka 3 w/GPU.
FSP FlexGURU 250W/300W Flex ATX PSU Pinout Attempt (Not Verified)
Hi, I'm not understanding the best way to mount my gpu in the velka 5. right now the lower part is sagging towards the side panel and one of the fans makes contact with it. I don't understand all the brackets etc that are included and am not sure what to do. the GPU is a zotac rtx 2070 super mini and it is narrower by a few mm than the compatible dimensions. the panel between the Mobo and gpu also flexes towards the Mobo because the extension cable is too wide it seems.
I will upload pics, Friday at the latest.So many people fit the Aorus X570i in the case without modding..., how??? Some pictures would be great.
Forgot to mention the height of the ssd is 10.5mm with heatsink
Underside SSDs with heatsinks will take away space from the GPU. Any 2 slot GPU will take all the space between the back of the Motherboard and the side panel, leaving just enough space for the riser to separate the Mobo from the GPU backside.
I believe that 10mm will not fit, but don't quote me on that and wait for the answer from someone who tried it or from Michael. I don't actually believe that the heatsinks would even help, remember that the SSD will be smooshed between the Motherboard and the GPU riser. My Adata XPG (granted, not a very high end SSD) hasn't gone above 55°C yet and only has a 2mm heatsink. I'd say you can go up to 5mm before you obstruct GPU placement.
There are currently no shorter power buttons than the one the case comes with, but around January - February, cases will have power buttons that are 7 mm shorter than the current ones. These buttons will not be backwards compatible and I cannot say for certain whether this will allow modified Flex ATX power supplies to fit.
This has probably already been mentioned, but for my sake I will bring it up again.
I currently have a L9a with a fan duct on the VK-5, I'm getting max 70 while heavy gaming so temp wise it's ok. I have 2 ideas to improve it noisewise:
1: Purchase Noctua NF-A9 (25mm) for maybe better acoustics, it seems it would set the cooler at the case's 48mm.
2: Purchase C7 (or Cu or G) and replace fan with my L9a's NF-A9x14, would set the cooler at 46mm.
Has anyone tried these configurations?
I have the 3600X, when I get 70 c I am gaming so my gpu is always louder. I want to reduce noise when I am doing light work.I just purchased a velka 5 on dec 10 (wish I would have put order in before the dec 7 cutoff!) Also got an l9a so am interested in this as well. Thought about getting the c7 but decided against it due to higher acoustics.
Where did you get the fan duct madman? Seems like it reduces temps by several degrees by having one.
70 c... but what processor a 3600?
