prebsus
Updates:
Some shots with the case closed (I need a better phone/camera)
With some PVC tape I was able to bend the Displayport cables in place. So P6A-P8T-SI fits and works fine, both cables are 20cm. The HDMI cable is also in there.
Also I noticed a fitment issue. The top Displayport port can not be accessed, part of the tab over hangs it. I'm using the Louqe Riser and a Palit RTX 3060 Dual.
I'm also going to need to learn how to undervolt at some stage.
I had this same issue with blocked 1st DP port on the 3060 Ti FE. Seems like a pretty common issue for the RTX-3000 cards in the Velka 7...
nightshift
295
197
It is already up and running.
The only thing that you cannot buy from there is the velka specific flex atx psu.
This is awesome. All I need is some modular flex-atx psu. Geeek seems like the best choice by far as I could go for the Ehance Plat 600w L-type orientation with 20mm noctua fan and add optimal length cables (ideally 150mm 24pin, 250mm 4+4pin, 300mm 6+2pin), but they do not ship to central EU for some reason which is a bummer. Need to find another option.
GucksTV
249
510
www.youtube.com
hey guys! :) I just wanted to share my experience with the Velka 3 and add the compatibility of the new Asrock RX 6600 XT Challenger ITX which measures 179mm and still fits without any issues inside the Velka 3! Check out the Build Log for a better picture:
Hope you like it! <3
Reactions: FiftyFifty
GucksTV
249
510
www.youtube.com
For everyone asking about the Performance of that System:
There are my 1080p & 1440p Gaming Benchmarks with some thermal & noise tesing! :) Greetings from Germany!
FedericoP
Thanks @VELKASE Michael for making the Velka 5! Allowed me to cram a 3070 and 5950X in a sub 5 liter case. Lmao. I eagerly expect the next modification for future crazy upgrades.
Hi! Which 3070 did you put? I am planning to build my first pc and have to go very-SFF due to travel. I would like a 3060ti but possibly a 3070 for further future proofing
UncannyPally
Hi there, love the look and function of these cases. Out of curiosity, are there any planned revisions to update the PCI-E riser to gen 4.0, or the HDMI and DP extensions to 2.1/1.4 respectively?
labmonke101
84
40
most likely not as the parts don’t exist yet, or if they do you can do the upgrade yourself by ordering them through Taobao. For instance there are gen4 risers out there that work with these cases
VELKASE Michael
VELKASE
Oct 7, 2018
743
914
There is a PCIe gen 4 riser option planned for a few weeks from now.
HDMI and DP extensions: these are planned to be updated next year but they may still not support the higher transfer speeds with all hardware. I am working on a revised frame that gives a choice between using extensions and a direct connection to the GPU.
UncannyPally
Thank you for the response! This is excellent news overall.
I see you sell some of the cables that the case employs on your site currently. Would it be possible for the updated HDMI and DP extensions to be offered separately for owners of the current frame design once they're available?
FiftyFifty
66
126
Attempting to build a watercooled Velka 7 with 240 rad and 3060ti. Check out my build if anyone is interested.
Reactions: thelaughingman
crackerlegs
49
81
I'll share a nice trick if you want to remove the sata tray but still keep the motherboard straight.
That's cool - what are these and where could someone purchase them?
SingaporeanTaxi
Hi guys, VK5 user here. I currently need extra HDMI ports to connect a 1080p 60Hz display. However, when I try to plug a DP to HDMI adapter into the VK5 DP Extension, it doesn’t work. The adapter will only work if I plug it directly into the GPU.
I’ve tried using upgraded DP 1.4 extensions as well as active and passive DP to HDMI adapters. Any suggestions?
Images for reference of what I’ve tried:
VELKASE Michael
VELKASE
Oct 7, 2018
743
914
Active DP to HDMI adapters/cables should be used instead of passive ones.
Would you be able to try using a single active DP male to HDMI male cable? Having a series of 3 cables may be causing issues.
