Prototype SFFtime presents: U-ITX - 7L lightweight console case that fits 3slot GPUs
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
marianairam
Great, thank you, looks good.
Since I plan to travel with the PC quite a lot I am a little worried about GPU sag in the back, especially when laying the case on it‘s side. I‘m using a 5090FE. The solution I came up with was to drill two holes in the front panel and to secure the GPU to them with the two M3 mounting holes on them. Find a picture of a 3D printed proof of concept below. It seems to work well. Of course, I won‘t be using the 3D printed part to hold the GPU but will rather use it as a template to drill the holes in the metal front panel.
Does anyone see any issues with this approach? Any other ideas?
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Looks good to me!
Btw your imgur link didn't' work, this one does:
Reactions: NinoPecorino
dc443
75
28
I have a 5090FE on hand this time around! You stated 4 weeks just under 4 weeks ago, so I am hopeful I can get this build done before I go on another long trip overseas in December. 😁
Reactions: riba2233
er_wink
23
Looks good to me!
As a side question, @riba2233, do you have any way to provide something like this support bracket? I don’t have any sort of metalworking capability to DIY one myslf, but I would love to have a similar bracket for my 4080 FE.
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Hi @riba2233 , do you perhaps have an indication of when the new stock will be available? And would it be possible to buy without a riser cable?
Next week and yes, just shoot me a pm.
Btw an important notice for everyone from the US, shipping will be much more expensive until they figure out tariffs since I will have to ship via DHL; you might also have to pay some additional fees on arrival, I am really sorry but I can't do anything about it at the moment, just hope that they will remove them at least for de minimis or something similar.
robbee
n3rdware
887
1,403
If it’s any help, FedEx is usually quite a bit cheaper to ship to the US if you go through the intake with a sales representative.
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Thanks, I will check with them if they have some minimal quantities, base price is similar to DHL. Only think I'm concerned about is their lackluster service in the USA, I have read so many horror storied when Steamdeck launched :(
Reactions: octiny and rfarmer
er_wink
23
But in the meantime, as you sort that out, your shipments to other countries aren’t affected, right?
rocklobster
98
24
Hi @riba2233 - interested in shipping to the UK, got a couple of questions I'd hope you can answer:
Checking when the U-ITX or P-ATX will be restocked in black and estimated shipping fees?
Also, what length and PCI-E riser should I be looking at if I want to get a Gen 5 one off Aliexpress? (dual reverse?)
Recommended max thickness of GPUs?
Any advice for a horizontal layout? I'm planning on getting some speaker stands to elevate and give more airflow. The Fractal Ridge has 80mm fans along the GPU and CPU to exhaust hot air out, wondering if that's been used similarly.
I had a similar case from Taobao (S59) a while back but I found the workmanship rough around the edges, think I cut my finger on a few of the panels.
Cheers!
