Completed SFFtime presents: P-ATX V3 - 10.4L evolution of ATX console case
capy
33
Well 7900xt ref has standard height (111mm) so it should fit tightly (width wise since it is a 2.5 slot). Not sure for 7900xtx ref though, they don't provide that spec on official site and it is entered wrong on techpowerup. It looks like it could potentially fit tightly looking at the picture, but I cannot guarantee (it might be just a few mm to tall, unless your pcie port is in the first position, then it should fit ).
And the AXP-90 X53 cooler should work in that case with a Zen 4 GPU, right?
DaHans
68
27
So Am5 ITX and RTX 4090 Fe Should work right? I checked the FE dimensions and it yhould fit with a ITX mainboard.
DaHans
68
27
Thank you for the notice.
I will defintely check this. right now I have a GB 570i and this one still drives me crazy as the am4 socket is in a upper position on the board.
What length would you recommend regarding the cable from the 4090 FE to the SF750 psu?
I already have a 20cm from Moddiy.
Reactions: riba2233
FLiP
Just a concern regarding the link up double reverse riser, wouldn't the red plastic on the slot side hit the bottom of the case?
riba2233
2,002
2,609
Croatia, EU
www.sfftime.com
Just ordered 😁
Can't wait for it to arrive
Awesome, thank you so much!
Yeah I wanted to write here that the new batch is available so you can get it right away, it is ready to ship!
Just a small note, this batch is not invertible but has the better side panel and stand mounting system, same as how it works on the new N-ATX V2 :)
