Completed SFFtime presents: P-ATX, the 9L case with ATX and AIO support!
MarceloSiciliano
62
51
Cool! That would definitely ease my worries haha. For what it's worth Im running a founders 2080ti and a 9900k so it would likely be hotter than a average build.
Regardless I look forward to the update. Also it looks like the release is looking like mid September? Is that still the case? I'm eagerly waiting for my chance to get on.
Im planning to do the same thing but i think there is no room for fittings on the GPU block
EDIT: Im using a MO-RA 3 420 too, for cooling my 9700k and 2080Ti
SpringerTheNerd
195
209
32
Seattle WA
Worry not! Here is our solution!
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
OP did say that there will be a version that's slightly thicker to fit 3 slot GPUs. I'm certine it will fit on that version with some 90° fittings
Yeah that's right, but I will also test if you can fit standard angled fittings on a waterblock, I have one from EK.
BTW nice find for that angled terminal, I didn't knew it existed :)
I am planning for second half of September, but since I depend on few other companies I cannot guarantee. But I'm doing my best to launch it as soon as I can.
SpringerTheNerd
195
209
32
Seattle WA
There is also this one. It's even more flexibility but personally I'm not a huge fan of how it looks
Reactions: riba2233
MarceloSiciliano
62
51
From my measurements it wont fit... But Koolance has a low profile 90 degree ta might fit...
Reactions: riba2233
Cactopos
Can't seem too find how thick the aio rad can be in the 9l model. do you have any measurments?
(BTW the case looks amazing! and im looking forward to being able to order one of the bad boys)
MarceloSiciliano
62
51
Can you check it this fitting would fit with the 2 slot version?
I found this Sketchup component of it.
MarceloSiciliano
62
51
Yeah I will check tomorrow, I need to make some measurements on my EK wateblock.
It better fit...or i will make a hole on that side panel lol. This case is PERFECT for what i want to do, this is the only issue that could make me not buy it.
This reminded me of a skyreach mini with holes on it side to fit Dominator Platinum ram modules
Reactions: riba2233
zzmadd
136
66
Italy
Here is how you can fit a threadripper, 1080ti and AIO into 9L case:
No wasted space and there's still space left at the top for three 60mm case fans
Question about liquid cooling.
The Zotac 1080Ti in the photo measures: 211mm x 125mm x 41mm
I mainly build hackintosh and often I have Radeons of this size: 235 x 145 x 45. Does it fit with liquid cooling or I shoudl switch to a 92mm radiator?
Thanks a lot.
Reactions: Cactopos
riba2233
1,999
2,605
Croatia, EU
www.sfftime.com
I mainly build hackintosh and often I have Radeons of this size: 235 x 145 x 45. Does it fit with liquid cooling or I should switch to a 92mm radiator?
Thanks a lot.
120 mm radiator would fit well (up to 243 mm is fine), but unfortunately 145 is to wide for this case. 134 is maximum width if the pcie slot is in the first position, and 115 mm (reference width) is the maximum if the pcie slot is in the second position.
Also, 45 mm sounds like it's thicker than dual slot. This case is limited to strict two slot (42 mm with backplate and 38 mm without).
For a gpu like that I recommend the larger model which will fit any gpu.
You're welcome and I'm sorry that it doesn't fit GPU like that, but I had to make some limits to achieve such a small volume.
