Production SFFtime presents: N-ATX V2 - 15L evolution of console case that supports ATX size parts
mrp0p1nfr3sh
67
44
Every 2-3 months, I am working on the new P-ATX V3 batch right now which will be available soon.
fantastic cant wait to see it so i can order one for my spare ATX build. Question has anyone built either case with a 2 slot GPU and a single slot add in card?
MarcParis
Apr 1, 2016
3,597
2,676
Here I did with 2 slots GPU. No issue as you can adjust space between side panel & GPU.
Sorry : Misunderstood your question..:) You need either a riser or DIY direct rear exit (as stated below by @riba2233)
riba2233
SFF Time
Jan 2, 2019
1,315
1,775
www.sfftime.com
Thanks, some users asked me about that option but I have never seen it done. The case is not designed for that but it could be done with some DIY.
Reactions: MarcParis
MarcParis
Apr 1, 2016
3,597
2,676
This half-size expansion slot for 1st PCIe slot would be a great addition for N-ATX v3..:D (You already know I'm supporting this idea since long time..:))
There is indeed enough space above GPU (see below RTX 4080 FE) and below CPU cooler..:D
Neathdrawls
235
420
Ok, supposedly last update/upgrade of my N-ATX v2.
Now with ATX 3.0 PSU, the FSP Hydro G Pro 1000W. Compact enough at 150mm in depth, still feels like it's almost the right size to fill it up. Of corurse, custom cables for it is essentially cheating, as I don't think the stock, normal flat ribbon cables would have worked well.
Also with 3 Noctua 40x20mm up top, way quieter than the Sunons.
2,413
2,489
Build looks great. Custom cables in SFF is smart not cheating.
riba2233
SFF Time
Jan 2, 2019
1,315
1,775
www.sfftime.com
This is really awesome, truly an endgame config for this case. Congrats, extremely neat and well built!
riba2233
SFF Time
Jan 2, 2019
1,315
1,775
www.sfftime.com
I tried to put an RTX 4090 Strix, and while it fits, the power cable interferes with the Ram slots. any chance for a slightly larger one? I would love to be able to fit a 4 slot card + an ATX mobo. Please make this a reality I would pay double
Ok this looks crazy haha! I was thinking about a larger version but I still have to figure out the perfect layout. Once you go beyond this very optimized layout you have a few different options and things get a bit messy.
Reactions: Kreasu
Kreasu
It would look even better with the white version! Let me know! I would gladly pre-order one right now :)
This would be interesting if it could fit too:
JF13k cpu cooler. Chinese low profile 240mm cpu cooler. (it's 92mm though)
MarcParis
Apr 1, 2016
3,597
2,676
This 4 slot GPU is clearly NOT a SFF friendly part...:)
You can move to ITX MB then..:)
MarcParis
Apr 1, 2016
3,597
2,676
This CPU cooler should work perfectly inside Cerberus Case...:)
Kreasu
I'd like to stick with amd for heat load reasons, but the 7000 series x3d only board that supports thunderbolt with dp in is an atx Asus pro art board.
I have an itx and 13900k lying around but I think running that on a 79mm cpu cooler wouldn't work very well
MarcParis
Apr 1, 2016
3,597
2,676
I also think atx mb are better than mini itx…;)
Issue is that your gpu is too large for N-ATX or too long for Cerberus-X…that’s why I was mainly focused on FE edition GPU..:)
Kreasu
Will our 2000W Enhance ATX-3920 fit? (aka CoolerMaster M2000) a little longer at 180mm or just standard ATX form factor 140mm?
I think this will depend on your gpu length and how long your cables are. Even though I can fit an atx psu in, I used an sfx for shorter cables and more space to cable manage
Reactions: Otamot
harryshuman
34
Holy Moses! I want one. This might actually save me from trying to cram Accelero Xtreme 3 into the case.
EDIT: just ordered
@Kreasu I think the only way to fit a 4090 into the case without breaking things is to use either one:
a) 4090 Founders Edition, it's the smallest air cooled 4090.
b) MSI's Waterforce RTX 4090. It's only a 2 slot AIO and if you use slim fans you will have enough space to route the cables around the pipes.
