Stalled [Pictures of Prototype] Densium APU, 3L, HDPLEX 250, 47mm cooler, Hardwood frontpanel
thelaughingman
1,410
1,564
as I've decided to increase the size of the case, in return of Flex-ATX PSU and taller CPU coolers.
what is the new CPU cooler clearance now that the case is larger? IMO 70mm for a Noctua L12S / Big Shuriken 3 would be great. LP GPU theoretically sounds good but in reality not so much. So APU build is what I'm considering for this case!
EDIT: Found A2000 for cheap locally so screw it 🤣
Densium.net
191
309
October 26th 2022 Update
Haven't updated you in a while, because I've been busy re-designing, making renders and a webpage! It's now available for Pre-order! I've now added some updated pictures to this thread, but there are tons more on the product page. I've also updated the AR link at the top of the thread!
Regarding the features discussed here on the website - I just went ahead and added everything, lol. The case now got Flex-ATX support, HDplex 250 support, 67mm cooler support, LP PCIe support (hdplex PSU only).
Some additional features are: Magnetically attached frontpanel, ventilated back-panel and the beloved USB-C!
Prototype is being manufactured now, but this will be the final iteration - no major changes beyond this point. I'll make 50 units first, unless it sells unexpectedly well, so the production time will be short.
When the prototype arrives I'll firstly validate the design (in all configurations) and test the tolerances ETC.
After validation, I'll take some photographs and more importantly: make an assembly video.
The 67mm CPU cooler support means we'll fit an ID-Cooling IS-55, but with a full thickness fan (25mm), and this is what I'll be using during the assembly!
Also I'll be sourcing an 1-slot LP RX6400 which I'll also be looking to fit inside!
robbee
890
1,408
Looking good! Am I right in assuming that the HDPlex allows the motherboard to be mounted a bit lower, opening up space for a single slot pcie card?
EDIT: should've looked on your website, very clearly explained there. Very nice solution to maximise compatibility!
thelaughingman
1,410
1,564
Instant buy! Thanks for the free global shipping as well!
Now is the headache - Lone L5 vs. Densium 😅
  • L5 can support RTX A2000 stock but is slightly bigger and needs a brick
  • Densium uses HDPlex GAN and smaller, but I'll have to find a way to make A2000 into single slot
Bakaban
124
114
Someone in this forum made a thread with selfmilled copper heatsinks for making his a2000 single slot. Believe he was selling them as well
Reactions: thelaughingman
robbee
890
1,408
Using a 90 degree riser, perhaps you can stack a dual slot LP gpu and the hdplex at the top of the case if you mount the motherboard as low as possible?
Reactions: BaK
thelaughingman
1,410
1,564
my preference is to avoid all the risers in the world 😅
@Densium.net from the product page "[The case also has 11mm of clearance for backplates]" => is it possible to use shorter standoffs to reduce that clearance to 8mm and increase cooler height clearance to 70mm? Would love to keep using the Big Shuriken 3, it is an awesome cooler
Reactions: Densium.net
Densium.net
191
309
Yes you could potentially do this, but you wouldnt fit the IO-shield properly
Exist50
43
47
I think this ended up being a good compromise between all the different asks. It's bigger, yes, but that was necessary for flexATX support anyway, and I like how half height card support was added in with minimal overhead. That should be handy to cover some uses not quite handled by integrated GPUs or motherboard IO.
Densium.net
191
309
Also think the 1 slot card is great for people who want to use an old CPU without iGPU to build a home server or media PC. Could just purchase a gt1030 for dirt-cheap
Legion
364
402
UK
I think you're out of touch with how much money said people have to work with !!!
$160 case +taxes and shipping + additional PSU cost is not on their radar......
This is an enthusiast class product, nobody buying it will be putting an old CPU or GTX 1030 in it lol.
That market is entirely different and certainly not at this price point !!!
Densium.net
191
309
My point is that I was trying to make the case as versatile as possible.
Reactions: steelfractal
steelfractal
Aug 15, 2019
588
719
35
denmark
when fitted with the GaN will you be able to place some slim fans where the 1-slot PCI-E card goes and what size fans fit
