Funding Gemcase C8 APU 4.1L - 65mm cooler, GPU, hdplex, flexATX
GEMCASES
GEMCASES
Jul 23, 2023
74
81
We are announcing new Gemcase C8 APU this is a mini ITX PC case with external volume ~4.1L. The case supports internal PSU HDPLEX and low profile, one slot GPU(or another PCIE device) it features space for two full sized 80mm case fans to maintain, a consistent temperature while creating minimal noise. Also case features the ability to be installed horizontally(HTPC like) and vertically(PC like usual). Another option is using FlexATX PSU but in such configuration case fans and GPU installation is unavailable.
Technical characteristics: Size(Height x Depth x Width): 220mm(8,6") x 213mm(8,4") x 88mm(3,46")
Volume: 4,1L
Weight: 0,4kg
Motherboard: mini ITX
CPU cooler clearance: 65mm (with 6mm clearance to grille), 67mm(4mm clearance, also available extreme not tested option increasing clearance to 6mm*)
DDR clearance: any
Graphic card: low profile(Width 70mm), one slot(Height 20mm), Length 182mm(GTX1650, RX6400)
Storage: only NVME SSD
Power supply: Flex ATX, HDPLEX 250W
Case fans: 2x 80x25mm(top placement - exhaust)
Materials: stainless steel and steel powder coated; front panel - oak(maple) wood with oil coating
Package content: Case, power button, screws, rubber feet.
*notice while using flex atx PSU case fans and gpu setup is unavailable
Release date mid 2024.
Price - 120€(130$)
ASAP
Any update on the release of this case? It looks great and I would love to pair it with the new 8700G.
GEMCASES
GEMCASES
Jul 23, 2023
74
81
We have now received all accessories(components) to produce first sample. We will make first sample and report about further production.
Reactions: Maybe and Arboreal
Maybe
Finally I found the perfect case after searching for a Year!
CPU cooler Support, HDPlex, 1 Slot LP GPU and that all with REALLY clean design!
Keep us up to date with the first samples! I would love to buy one!
And of course keep up the great work! :)
Reactions: GEMCASES
GEMCASES
GEMCASES
Jul 23, 2023
74
81
Hello, we found you and you found us:))
It is great!
This week sample case will be ready but firstly we have to complete C9 orders and than will start production of C8.
I think starting July C8 will be in stock.
Reactions: Maybe
7,617
у вас есть телеграмм? Дискорд не работает
"do you have telegram? Discord is not working"
Please post in English as per the rules you agreed to when registering.
