GPU Official GeForce RTX 30 Series "Founders Edition" Dimensions
kenrico
I am limited to the previous evga XC / black sizes like 270-280mm with a Lian Li Q10WX . Looks like ASUS Dual , MSI Ventus or Zoltac ??
Anybody else spot some smaller cards below 282 mm ??
MEGATAMA
Guys i m soo sorry if this is wrong topic but i need help... i m in search for 3080 model wich will fit my system...i would like again Asus Strix but i think new one dose not fit ?
This is my system now... sorry on my bad english.
Kuciste:Sliger SM 550
MBO:Gigabyte Z390 Aorus
PRO WIFI-CF
CPU:Intel Core i7-8700
GPU:Asus Rog Strix 2080 OC 8G
RAM:Gigabyte Aorus ddr4 16GB 3200
PSU:Corsair SF750 Platinum
SSD:Samsung EVO 970 500gb
SSD2: Samsung T5 ssd 1TB
Tipkovnica: G915 Lightspeed wireles
Mis: G502 Lightspeed wireles
Headphones: Sennheiser HD 569
Display: Samsung Q90R
MarcParis
Apr 1, 2016
3,834
2,996
Well to be honest, for RTX 3080, only FE is 2 slots but you need to check gpu length and airflow.
For RTX 3070, you will have plenty of choices.
PRO WIFI-CF
Same here with my SM550. With my panel mod on it (have a look at the link of my build log below), a gpu with 48mm thickness from bracket (not considering back plate) is fitting inside SM550, like my GTX 1080ti Gaming X, 51mm thick in total.
However despite that mod, it’s hard to find a 2/2.5 slots RTX 3080. Best hope I have for now are Evga XC3 and FE version but this later could kill PSU on mid term...but this needs to be check
ermac318
655
510
The EVGA XC3 appears to be the best option for people with limited case space, at least so far. It's only 2.2 slots and not that long. It may not perform very well, but it's better than not having something that fits at all.
Reactions: MarcParis
MarcParis
Apr 1, 2016
3,834
2,996
Can this one fit in my case,it seems smaller then this 2080 strix i have?
Nope as this gpu is 2.7 slots. SM550, even with my small mod, is only compatible with up 2.5 slots gpu.
Thanks for sharing this info of 2.2 slots of XC3.
Let’s see reviews/tests...:)
fabio
1,885
4,325
Just a public service announcement: the 12-pin connector seems to be a Molex Micro-Fit, NOT the Molex Mini-Fit Jr that most connectors on a modern PC and PSU use.
So be mindful that the currently available 12-pin Molex connectors (and pins) at mod component shops are probably not the correct ones.
If this is true, we can still hope in a FULL single slot Watercooler 3090/3080!! The 12 Pin Micro-Fit is 18.5mm long... Let's see.
I am wondering why the Reference Cards are not using, in any case, the 12pin horizontally!
EDIT: The connector ON the board is 21.65mm (+PCB to be added). So can be a sort of Single Slot card, but not a real single slot one!
Reactions: Timothy
MarcParis
Apr 1, 2016
3,834
2,996
Here is EVGA XC3 RTX 3070 (fingers crossed RTX 3080 & 3090 dimensions will be the same) :
  • Length : 28.5cm
  • Thickness : 2.2 slots
  • Power connector : 2x8 pins
If it's confirmed it will be perfect RTX GPU for SM550..:D
Source : https://wccftech.com/evga-closer-look-geforce-rtx-3070-xc3-graphics-card/
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
ermac318
655
510
Judging by the length and cutout for pcie power connectors on that waterblock, they should be in the middle of the card, but XC3 has them at the end.
It doesn't look like a reference 3080 PCB but that is a 3070 which may have a totally different PCB layout. The reference 3080/3090 have the PCIe connectors somewhere like 200-220mm from the IO Bracket
Reactions: riba2233
ermac318
655
510
I really hope that's the case.
Well, EKWB has said their waterblock is 230mm long, so if you look where the vector notch is (which is also removable) thats where it puts the power plugs. Two 8-pins is like 3cm wide? So it's probably in the neighborhood of a 220-ish long card.
riba2233
SFF Time
Jan 2, 2019
1,923
2,524
www.sfftime.com
Yeah but I was talking about the evga's XC3 models, I was hoping that they would use reference pcb's. Maybe they will for 3080 and 3090, who knows.
